needed help...
tunchin
Dec 26, 2012
7
Segamat
hi guys,
recently i change my fortuner 2.5g Diesel nozzle and added a "RACE CHIP"..
the car is much more powerful and the top speed increased... BUT
when it reaches 4th gear, i realised black smoke came out from the exhaust (of course lah) but its seems like a Lorry exhaust smoke.... and sometimes when i step on the gas paddle, the engine warning light appears and the whole car langsung cannot move... have to turn off the car and then start back baru can jalan... (this happens especially when at traffic light stops and full acceleration)
what can i do to solve this matter... pls help... :sob:
tunchin
7
Segamat
Em m?i tham gia di?n dÃ*n. Chua bi?t gì nhi?u, hi v?ng các bác giúp d?. BÃ*i vi?t c?a c?u hay quá tôi . C?u nÃ*o c?n v? d?ch v? ki?m d?nh vÃ* hu?n luy?n an toÃ*n: xe nâng, c?u tr?c, n?i hoi, thang máy thì liên h? tôi nhé.Chúc b?n thÃ*nh công
I don't understand.
---------- Post added at 06:37 PM ---------- 6 hour anti-bump limit - Previous post was at 05:41 PM ----------
hi guys,
forgot to mention, my fortuner is model year 2010, auto. :smokin:
huakenny
LB Performance
9,126
240
Kota Kinabalu
Race chip got few preset mode, switch to the one that is not so AGGRESSIVE
the map is too aggresive and ur car cant support, so it jumped into LIMP mode(check engine on), boost too high etc issue
when u switch off engine and restart it back, it back to normal...coz ecu cant detects any problem
happen only when u WOT rite?
tunchin
7
Segamat
WOT? actually i am very very very new and dont know what is all the short forms... hehe... but the black smoke is outrageous
attached picture is the 1 i took from my racechip... the setting... pls advise how to set..
huakenny
LB Performance
9,126
240
Kota Kinabalu
Racechip is getting famous nowadays, being in gasoline or diesel engine.
how to set it right, guess you need to consult the racechip seller for advise bro....
simpy turn the switch will just kaboom it :p
and yea, izso is right..WOT is 100% full throttle
*btw, i will direct your problem to the Racechip since i know them
ckh_calvin83
12
what's that piece of white thing at the pin area? where do you get the racechip from? got reseller in malaysia?
tunchin
7
Segamat
Yeah.... Thanks..really appreciate it huakenny.. Actually I bought this racechip pro from a shop who mod diesel nozzle.... He said adding racechip can increase hp a d top speed.... So currently I only can manage reach 160km/h max
---------- Post added at 10:20 PM ---------- 6 hour anti-bump limit - Previous post was at 10:17 PM ----------
The white piece is the jumper.... Normally found in electronics circuit. Reseller? I think u better ask huakenny. I install it via the fella help me mod my nozzle.
---------- Post added at 10:25 PM ---------- 6 hour anti-bump limit - Previous post was at 10:20 PM ----------
WOT = wide open throttle. Ie - full throttle
Thanks for the infor.... .... Yes.... It only happen when I WOT.. Now better edi... Previous when started install.... It happens every time I WOT.... Now once in a while.... But the black smoke us totally crazy.... Especially at 4th gear.
tunchin
7
Segamat
and... donno is it because i changed the nozzle... the engine sound more louder than previous....
Hi . i'm looking for the urethane foam (usually in yellow colour) . it's not like the bekas ikan (white colour) .. it's solid urethane foam ..
need it to do some custom audio enclosure ..
oh one more thing , do u think i can get the plywood that they usually used for cargo at port klang ? need plenty of if .. the wood smooth surface and thick are perfect for MDF rings ..
