modified air filter
weikhee86
423
i just found a suitable air filter for my proton tiara..but the old air box i have to throw away to make way for the filter...i bought the type with metal wire mesh on da outside..a bit like cone one...will it affect my car in the long term? i can feel the difference in performance already...is it becoz of da new air filter? need your opinion guys...
gloss
1,546
SJ
your car have a new breathing organe..
congra!!
"affect your car in a long run" .. in which sense?
weikhee86
423
how it is? what kinda filter is this? me noob here..
weikhee86
423
the old air box gone..completely gone already...say hello to my new air filter...i can feel the acceleration jump up...or is it my own thoughts?
howiechoo
8,000 RPM
8,857
Bukit Jalil
according to some ppl, they say u feel more power is because the stucked old filter is removed and u put in a new filter which is not stucked by dirt..and it increase the air flow...so u feel more power..
btw, i think aftermarket filter all had higher flow than ori. but the problem is, the increase of power vs the increase of fc....
once u changed filter, mostly fc increase...if fc>hp, then not worth it...but it depend on personal preferences...
weikhee86
423
ic...need to put air ram? o just connect to the head n straight to the carburettor good enough? without air ram the air come in too fast right?
cybreed
olSkool
123
6
Kuching Sarawak
www.randomshutter.com
more power = more fuel consumed.
why more power? because your engine gets better air flow from your new element. Over the stock one, the new one has bigger 'holes' so the air particles can flow in better and in higher volume. So now you have more air(oxygen+other gasses) most likely your mech retune the engine to compensate for more air, but adding more petrol flow thereby increasing more fuel for combustion making a powerful bang.
more bang more power more power more fuel
sam1741
1,188
i still dun understand why ppl always FUEL consumption INCRease?
the power comes because engine no need to 'pull' so hard to suck the air in
what way it will increase the fuel consumption?
in fact i think better air flow will improve your fuel economy
cause the engine no need to pull the air in so much (in case of dirty filter)
and can use the power to move the car more easily
well unless ppl always rev the car after changing.. than offcourse FC will hurt
but if u maintain your driving habit
i see no logic where the increasing in fuel consumption
weikhee86
423
i went to the exhaust shop to custom ram for the new air filter just now...but the tauke said better fix back my old filter/air box becoz according to him, although using the new filter makes it more powerful, but is also increases the risk of the car's engine catching fire as sometimes the petrol might get sucked back and the heat from the manifold below could cause a fire if u run it for long distance...is it true? he said one of his customers ever kena once liao...the whole engine terbakar...what's ur opinion guys? plz help..shud i continue using o follow his advice?
gohkokeng
2,443
lol again?
ok changing AIR FILTER more fuel consumption?
logic is here......sendiri think. Same like human,
1st = Air is free
2nd = More air no good?
2rd = Cleaner air no good?
yinho
382
one of the major prob for open port air filter is because heat. We know that when engine is running, the temp in the engine bay will rise. For normal road car, when the car is moving forward, the air circulation will flow from engine bay to under the car then to free air. When the car is stagnant, the temp in the engine bay will increase, thus the air filter will tend to suck hot air. As a result FC increase.
Original airbox provides natural CAI. Depending on your air filter configuration, IMO these air filter are actually designed for turbo charged car because it requires much much higher air flow than equilvalent NA engine.
weikhee86
423
ic...yinho thanks for the info..think better change back to old filter cos my engine is NA..better for FC rite?
yinho
382
weikhee.. my suggestion is just stay with your new air filter since u feel the car is easier to rev. wait till u really fed up with your FC or sluggish performance during hot afternoon then u might decide to change it back or add your own CAI. FYI, cheaper filter (some does look exactly like those famous brand) does not provide good filteration. so small particles might have changes to enter your combustion chamber.
weikhee86
423
oic...yeah for now testing pakai only..thanks for the info bro.. :)
BenjieTan
32
WeiKhee , so how was the open air pod filter after using it for one year ? Engine got overheat? Fc got increase ? How much did u buy that thing? Very expensive ka ?:hmmmm:
weikhee86
423
so far so good but I bought one K&N filter and I'm currently using it. Very satisfied with it. One reminder: keep a light foot when you drive to save fuel and floor the pedal if you want to rev it high. Flooring the pedal very makan minyak but sometimes I do it just for the adrenaline rush. :D the filter costs me around rm240 for a small one. Quite pricey but K&N can be washed and reused. So I save in the long run. :burnout:
GT_AUTO
3,503
71
K.Trg
www.facebook.com
i don't think changing a high flow filter will increase ur fc.the easier the air can
get in to the combustion chamber,the less effort the engine need to suck
those air compare to paper element n the lesser u need to press the paddle.
try breathe through paper n c how hard it is for the air to go through those
paper element.just my 2 cent.
K_Takuya
Moderate Moderator
Sep 1, 2005
1,954
153
Limau bali,Ipoh
using aftermarket filter wont increase fc.... if more air in.. the combustion will be better=better power..so u wont need to press the pedal hard to quickly get to the speed u want, just a light press maybe enough...
maybe u should do a heat shield. u can even DIY it..go to workshop and look around for an idea..u can use aluminium foil....plus Cold Air Intake (CAI) using a hose..
Ferrari has constantly denied the existence of a new baby Ferrari, but it keeps emerging everywhere, guess Ferrari is just trying to make a hype of it before its debut. Expected to be introduced at this years Paris Motor Show, the successor to the legendary Ferrari Dino will be possibly named the GT420 or 470 or maybe just, Dino all over again.
To be based on a shortened platform of the Maserati...
