Mivec with 4WD gearbox- anyone?
boyzone
2,669
38
5,148
Guys,
Behalf of my fren to bring up this question.
he mivec gearbox got problem, plan to change but quite expensive to get back original. workshop offer him 4WD gearbox with very reasonable price..
Anyone running this set up before? can share opinion ? :hmmmm: Thanks
jinkl
4,623
376
3,183
ratios wont be nice
most 4wd mitsu gb's are close ratios and they r short u cant pull revs
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
not to mention the car will be heavy.btw,imagine all the hp have to drive
all four wheel.u might disappointed with the out come of the conversion.
u wont feel the power as it used to be.
boyzone
2,669
38
5,148
err... check on the 4WD gearbox's ratio .. gear teeth ratio number is low ( e.g 2.98 vs 3.083 at the 1st gear ) but cover with high final drive ratio ( >4.9 ).
it should given slow rev up but better high speed right?
Example :
3.083 -> 8000rpm = 50km/h
2.980 -> 8000rpm = 65km/h
Pls advise.. Thanks
zzainudin
503
Subang selangor
bro i'm using mits 4G92 Non-Mivec ori 4wd from h/cut (lock to 2wd), pick up can rev until 7k++..
ok what,top speed can go 180 Above..
actually what engine r ur friend running
jinkl
4,623
376
3,183
which 4wd gearbox u talking bout bro
evo's 1'st and 2nd are very very short
boyzone
2,669
38
5,148
My fren engine is Mivec.
Btw, I not very sure what 4WD gear is it as not familiar ..
If not mistaken, is took from 4G93T.
cooljas
523
gentleman,
Lets get things rite here, the mivec gearbox ratios r shorter than the evo's or any mitsu turbo gearbox
cooljas
523
Example :
Pls advise.. Thanks
longer ratios gearbox will have better top speed...
The one tat u gave example about 4.9FD on a 4wd gearbox...tis is a special gearbox and very diff to find in da market...
deacon
Senior master debater
1,165
30
4wd gearboxes are proned to higher loss from flywheel to wheel even when locked to fwd correct?
boyzone
2,669
38
5,148
Actually most of the 4WD gearbox is ready with >4.9 final drive ratio.:biggrin:
Btw, anyone had been tried with 4WD gearbox?
cooljas
523
maybe u should let all of us know which turbo gearbox got 4.9fd.....thanks
jinkl
4,623
376
3,183
all evo's have 5.X final drives
u could try , bt in my opinion u will loose
the long revs cos its gonna shorten ur pulls
cooljas
523
pls bare in mind tat the individual ratios r very long....the gearbox juz have a bigger final drive.....calculate back...it might be worst than a mivec gearbox
boyzone
2,669
38
5,148
ya.. u are right. maybe will loose up 1st gear pick up abit.
fct
211
kluang,jb,spore
think there is 4wd version 4g92 mivec in japan.
2w ratio(mivec) 4w ratio(4g92) 4w ratio(vr4)
1st 3.363 3.083 2.846
2nd 1.947 1.684 1.684
3rd 1.285 1.115 1.115
4th 0.939 0.806 0.833
5th 0.756 0.651 0.690
Final 4.592 5.208 4.933
transfer gear NA 1.090 1.090
pls compare these few gearbox
boyzone
2,669
38
5,148
Thanks...
my bro just go to 4G92 non mivec with 4WD gearbox..
will keep update.
I bought this Vacuum and Volt meters from Speedster_jg recently I must say it is well worth it. It was expensive to actually get it installed at Kelana Jaya "ABANG" , RM35 to be exact to DIY is preferred.
After all the reading at ZTH, I got the meters working; but I wonder how accurate the Vacuum reading are. I can't be sure where the T joints are correctly placed or not.
The attachment shows where i made the T Joints on my Satria. Also, can anyone pin point me the area where i can...
