4G92 Mivec
Triplej94
Jun 22, 2017
13
Kuching
I have a proton Gen 2 which I bought from a friend. when he bought it before it was already running on a 4G92 mivec engine. so both of us did not know what type of 4G92 it was specifically.
I've did some research, probably it's a CJ4A or a CK4A. I'm confused. :dontknow::dontknow:
characteristic of the engines is, Mivec change over at 6800 RPM. I've check the ECU code which is 2556. however, I was told the engine is a 4G92 mivec RS. :confused:
sanekit
Dec 9, 2015
1,616
157
663
thanks for the info.. any idea on the differences of the RS version and non RS version? I heard that the RS version comes with a higher cam?
i don't really know. usually engine specs all the same. only the interior and exterior is different. need to check online about this.
Probably same like VR4 and VR4RS, engine same but have bigger injectors and larger turbo, different ECU of course.....
lsm1991
1,469
185
PJ
and likely the gearbox... rs typically has some sort of lsd where as the gsr, i think sometimes tarak? i could be wrong
Nightstalker1993
267
130
1,543
Subang Jaya
Looks like nobody answered your initial question.
Mivec RS vs Mivec normal, Mivec RS have titanium intake valves, different cams with more aggressive lower cam which is why the mivec switchover is at a higher RPM. Water/oil cooler at the rear of the block, oil squirter jets on the block for piston cooling. Mivec RS engine also sometimes comes with an LSD gearbox as well. Gear ratios are also slightly closer if not mistaken but I had forgotten the details.
<img src="http://www.zerotohundred.com/wp-content/uploads/2012/07/DSC0262-600x400.jpg" alt="" width="600" height="400" />
One of the astounding characteristics of European cars is that they have this “sleeper” look that somehow suggests that it is more sedate than it really is, designed to transport occupants in comfort and luxury. While those facts are true, it is a known fact since the days of our fathers, that these well-built euro machines are not to be trifled with. Even more so now...
