mivec turbo project
jtdw
12
malaysia
hi, to all sifus, i would like to convert my wira aeroback to mivec turbo. Mivec head +gsr block + microtech ecu + tdo5 twin fin. If any sifu out there that currently successfully convert this project, mind to give me some comment regarding reliability and performance. pls comment thx..........
gtishadowfax
915
mivec turbo = evo IX!!
a friend of mine tried this project a couple of years ago, but it was not accomplished ...if i'm not mistaken the major problem is to re-write the chip, to make turbo and mivec work/spool/open simultaneously and to get proper torque level at different gears...
the main objective/achievement of mivec turbo as in evo ix is u'll have a very powerful torque at any gear, so the car doesnt feel sluggish/almost eliminates the lag caused by turbo spool...
do correct me if i'm wrong. bro, if its successful, pls post and share with us...
Cohiba
455
Mivec turbo is all about having loads of $$$$$$$$$$$$$$$$$ :regular_smile:
the best is to include pistons,conrods,etc...the whole works..and the only thing that ive noticed that gives way once u have high hp/torque is youre crankshaft...
but if u have the cash,go for it i.m.o ......really good IF tuned rite....
keep us updated on your project ......good luck:regular_smile:
jtdw
12
malaysia
will go on with this project
hey, i am going on this project very soon after gather all the necessary parts that need for the transplant! will come back soon thank for commenting!
jtdw
12
malaysia
beyond_4896
278
jb hv racing have do a car now.
Boost 1.5max boost, with t04e. microtech.
damn damn fast!!!!!
boyzone
2,669
mivec head with GSR block ?? how about piston ? what's compressor ratio??
jtdw
12
malaysia
how fast
beyond, how fast are consider fast? hp? torque? can beat evo 3? or evo 9? pls discuss more thx you
equin0x
675
www.keiconcept.net
i was thinking also whether this can be done to 6A12 or not. FTO's 6A12 is equipped with MIVEC but then Galant's 6A12 is turbocharged. basically from the technical spec sheet of this both engine, bore and stroke of the engine is of the same except the compression ratio (NA 10.0:1 and forced feed one is 8.5:1). if given the MIVEC head will fit perfectly on the turbocharged block, how do one measure for a suitable compression ratio for this hybrid project? put the tuning for the powerband aside as it is of diff case.
GSR06
455
17
Better get an original Evo Engine. Less headache and original is better than rojak.
Cohiba
455
its common to see 350-450hp mivec turbos around...
but the question is if its reliable or not....in the long run sure got probs if not tuned rite...
boyzone
2,669
just prepare to stay inside workshop more than u drive out on the road. :)
Cohiba
455
Might be doing this as well...sigh...still contemplating though....
350-400 whp cukup laa kot :X-:
Danny@GSR
243
Bro, keep us inform. MALAYSIA BOLEH KA TAK BOLEH???????????
mesti boleh cause in Penang i know there is one Mivec Turbo runing on the road, but i never seen it.
Just done DIY Install Stromberg for my Charade Aura. I bought 6 units of Stromberg from Zerotohundred fellow nick name GTR a.k.a Ron. But since my V6 is at the workshop for upgrading my brake system so I decided to install these units into my Charade Aura first.
Later on I consult with Ron about this project. He said that my Charade should use only one big unit of Stromberg only:confused_smile: . He said that my car will jerking like Kancil. So I decided to test drive and found out...
