Mitsubishi galant vr-4 e33a
budakkampungaje
317
38
Dengkil
spec E33A produced from 1989 (october) AMG , Grade MX , VX-S,VZ-S
AMG SPEC......
Displacement, cc 1997
Engine model 4G63 ECI-MULTI
Max.power (Net), kw(PS)/rpm 170 ps (125.04 kw) / 6750 rpm
Max.torque(Net), N*m(kg*m)/rpm 19.5 kg*m (191.23 N*m) / 5000 rpm
Power density 7.35
Engine type Water cooling serial 4 cylinder DOHC16 valve
Engine information
Fuel system ECI-MULTI (electrically controlled gasoline injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 10.4
Bore, mm 85
Stroke, mm 88
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.6
Grade MX, VZ-S , VX-S
Max.power (Net), kw(PS)/rpm 145 ps (106.65 kw) / 6000 rpm(1989)160 ps (117.68 kw) / 6500 rpm(1990)
Max.torque(Net), N*m(kg*m)/rpm 17.8 kg*m (174.56 N*m) / 5000 rpm
Power density 8.14
Engine information
Turbocharger No
Fuel type Unleaded regular gasoline
Compression ratio 9
Bore, mm 85
Stroke, mm 88
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.9
hi pal..im planning to lowered my ride..was somehow come across this brand Sapura Leda spring..anyone got any experience with the spring..?mind to share some.. ;) i prefer more on comfortable ride..really need some feedback from all the sifus here..thanx B)
