Merc W124 E200 no reverse light
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
as the title suggest...
i did some research and discover that the nss could be the cause.since the nss on the
gearbox has its selector kinda loose to begin with i replaced it.
still,reverse light does not lit up when i select reverse.
both bulb and fuse is fine.
gunnerzz
2,109
695
713
38
Melaka
problem solved.
it was a wiring problem.somewhere it was cut.
too bad my bro was not around when the mech did the job.
the mech was even reluctant to saw the exact location.
also we manage to solve the rough idling and stalling problem.
it was a switch on the throttle linkage which was suppose to be pressed in every time the throttle is fully released.
my bro said its the take off switch.
just need to adjust the screw on the linkage to make the switch contact.
Hi,
I just bough a sedan wira original 1.6 auto which already converted to 1.8 4G93 turbo manual, after driving for a while feel that is not my liking.
I currently plan to convert it to v6 automatic.
I have a few questions probably all of you can share:
1. It is legal to do this conversion, body original is 1.6?
2. Which v6 auto is reliable? eternal or others? I only like v6 which I
like smooth/quiet engine :)
3. How much it cost to trade in this 1.8 4G93 turbo engine from my car...
