Mazda 323 Astina overheat problems..help!
May 20, 2012
hi everyone...
currently I just bought a 1993 Mazda 323 astina...but then i got few problems that i don't know..
- engine temp went to almost H when cruising more than 100km/h or high RPM
- before that same problem occur but after flush the radiator change new coolant still got the same problem
anybody know about the problem please give me some information about it...would really appreciate any information given...
thx :D
nyantong
192
50
Firstly, determine if your radiator fan is working. If not, it can be the relay / fuse or the fan motor. If it is, then next thing to look at is your coolant level. If there seems to be loss of coolant, try looking for leaks throughout the cooling system, such as radiator, hoses, radiator cap, water pump, etc. Even a worn out radiator cap which cannot pressurize ur cooling system can cause coolant loss. If there are no leaks, your next clue could be malfunctioning thermostat and or water pump. In which case it is recommended to change both. Hope this helps.
kmal
change new water pump and try it
ok...i'll try check at the workshop tomorrow... thx
alright..thx for the info... I'll check that tomorrow... :D
yeoopakcuy
102
Try to check the radiator. Sometimes inner radiator water passage corroded make the radiator clog and cause no cooling effect. When you do flushing, sometimes the air trap inside the radiator can cause it overheat. Try to bleed.
kmal
ooo... ok thx for telling me abt it...gonna check everything tomorrow :D
A Post Every 5 Mins
Hi all...I'm thinking of getting a used VW PASSAT 07 2.0 FSI for my wife daily usage (to go to work/send my 1yr old kid to day care center and balik kampung once in a while). Tempting with the price... RM80k++........
Spec..
6 Airbags
6 Speed Tritronic gearbox
Multifunction steering
GPS on board navigation
Bi-Xenon headlamp (New)
Automatic reverse side mirror
Electric Memory Seat
Climate control Seat
18" Caractere Rims
it shared the same engine as golf gti mk5 rite. Just wondering, is it a...
