Toyota KE70 - Old School Spirit
Engine
- 3T-C 1800cc
- 86mm 2JZ-GTE pistons
- Full Floated connecting rods
- Brand new T04E Turbo (58mm Compressor wheel, A/R0.63 Turbine housing)
- 40mm HKS Wastegate
- 284* High lift turbo cam from USA
- Racing Dual valve springs
- 600 x 300 x 76 mm Infinite Intercooler
- All stainless steel intercooler pipes
- Fully Programmable ECU (Fuel and Sparks)
- 4 Bar MAP sensor
- Real time barometric correction.
- Now tuned to 14psi on 450cc/mins injectors
Transmission
- W55 Gearbox
- New clutch pressure plate and ASCO Clutch
Front Suspension
- Cusco Silvia S13 adjustable
- Cusco Pillow Ball
- Long lower control arm (2” longer over stock)
- Silvia S13 brake (Front)
Rear Suspension
- Aftermarket coil springs
- KYB Short Stroke
Rear Axle
- Welded Toyota E-Series 7.1” Axle
Rims
- 14” German SIEG Engineering
Condition
Immaculate
Undercarriage never being welded after leaving
Toyota factory in Japan
All suspension bushes have been replaced
Original running 4K engine and gearbox will be
given upon vehicle hand over
Selling for RM10,000
Car is available for viewing anytime at Kuching
SMS/Call CHB @ 016-8504830 for more information
Engine
- 3T-C 1800cc
- 4 Bar MAP sensor
Transmission
- W55 Gearbox
Front Suspension
- Cusco Pillow Ball
Rear Suspension
- KYB Short Stroke
Rear Axle
Rims
Condition
Immaculate
