Iswara Rear Disk Brake
pentavalen
524
www.zerotohundred.com
HALLU GUYS
i drive iswara a/b, i wanna place the rear disk brake at my car.
so.. which one of disk brake must i use..
some body told me using mirage disk brake...
it's that true?
jombiee
950
13
Ghombau
yes its true & its rare & if got one its expensive - cost u around 7-800
FYI the drums on iswara 1.3 are enuff bro, unless u convert ur engine
upgrade the front disc pad, brake servo etc first ! front are far more important
fstr
7,935
954
Sahara Desert
there is a STICKY thread in proton/perodua about this topic, pls check it there. all questions and answers are there including pics.
e819
1,261
u can use mirage or vr4 pcd 114.3.. itll cos u around 350-450 with installation...
not 2 4get when u buy the rear brake pls ask then for hand brake kabel as well..
all the best bro
SkYwAlKeR
10,139
300
ePoh ~ malacca
plug and play rear disc brake for saga iswara is vr4 and mirage only lor...
others need to mod ler....
for example that STICKY thread uncle fred mentioned, he uses putra rear disc.... not really plug and play la... coz u will be running on different PCD for front and rear....
rear disc brake only help alot during higher speed braking... at lower speed, it works jz as same as drum brakes.... if u wanna improve ur braking performance, upgrade brake pump and servo first....
jombiee
950
13
Ghombau
Bro,
go search for VR4(have to mod a bit) or Mirage(pnp) front with servo, super grip & enough for your stopping power, will cost u around rm250-350 depends on conditions
minimum wheel size are 14, couse the set is BIG, ventilated & cross drilled(if u lucky)
good luck
e819
1,261
SM4 servor would be the best if ur thinking to change ur servo...
Today, I finally decided to go for the upgrade... been having sleepless night thinking about it over the last 3 days.
1. Woke up at 8AM, clean up n ready by 9AM.
2. Check my car - been having some coolant leaks over the last few days.
3. Start up and head towards Centre Point, BU for quick breakfast.
4. Called Stan at 10:45AM and fix appointment at 11:30PM.
5. Stan led the way - I'm hopeless with inner KL roads.
6. Arrived at MPD, saw many cars awaiting final tuning. Time was 12:15PM.
7...
