How to remove a sticker ?
lazychai
My bumper got a sticker that already stick more than 2 to 3 years .... now i would like to remove it but when i my finger nail is very hard.
So any one know how to remove it without scratch my bumper and the paint ?
Thank You !
acbc
4,615
KD
Thinner will eat the paint. Use spirit or petrol instead. Alternatively, run some petrol and burn it. Stickers will come up but don't let it burn too long.
gohkokeng
2,448
stickers can he torn out using your thumb finger nail...
slowly korek korek and korek then tinggal those black black sticky glue that time only u use those things.
plate dishes liquid with smooth kain lap on it hard and fast will do.
gohkokeng
2,448
use thinner, petrol, minyak angin cap kapak.....all those dangerous might affect or melt down your paint.....lol
the more worse......ugly sticker turn to ugly paint melting......
crazeeclan
320
shah alam
u can try using car wax to remove....i use those SOFT 99 car wax...around RM20 per can...confirm 100% can be romove without scratching ur car paint....
lazychai
i will try and see ... i did a research for that also ...
The website got teach how to remove the sticker.... it said use the WD40 to spray the sticker then use the BLOW hair thing to heat up the sticker then try to use a plastic knife to slow remove it.
But im not sure whether it working or not ... i will try anyways
Thanks
lazychai
FINALLY THE RESULT IS QUITE SUCESSFUL.
i just spray the WD40 at the sticker there then just use a plastic knife to remove the sticker. This need time and energy to 100% remove it. I don't think that need a hair dryer to heat up it. The WD40 is good enough. Then just use WAX to polish the sticker part.
THANK YOU.
alray
264
5,018
Selangor
Well, at least you have managed to safe ur fingers for something else for now. :regular_smile:
hyde013
32
i also heard b4 using WD40.. haven't tried b4... my car don't have sticker on it.. lol.. onli on the windscreen.. this info might help me in the future.. thx.. :P
kimmyboi
Kuching
well for decals and small stickers use lighter fluid as i have been told by body workshops, when i was doing my car.
And for the car metal emblem logo stickers, use hair dryer and fishing line. Heat the sticker for a while and then use fishing line the slice through
InitialD
1,302
93
Guys, just go to ACE Hardware store and buy this glue stain remover called Goo Gone
Just pour a little bit into the gap of the sticker from the car body. As u pull along, pour a little bit to dissolve the glue.
Finally, after u have removed the whole sticker and u see some glue stain then just pour some goo gone onto a cloth and wipe it away without much effort at all.
Guys recently i did a conversion for a GX81 to a 1JZ-GTE from a JZX81.. The halfcut comes with full dash and full wiring from engine to the back of the car not splice.. :driver:
Now after finish with the full conversion including all wiring and finally the car be able to drive and i found out that the car seems to have some engine miss up to at around 6krpm to redline.. I can onli know this thru listening to how the exhaust sounded.. I tried changing the 1JZ fuel pump to new bosch...
