how to modified 4g91
tyco263
5
i have 4g91 engine...
the probelm is, how to make my engine more pickup
gsrTurbo9166
958
hi bro.it is depend on how deep is your pocket.if u hv deep pocket then go 2 buy adjustable cam as my fren did.c la ur budget is very important.
tyco263
5
now my budget about RM 2500.00, what can i do it for my car with this budget...
i dont want to change my engine to turbo or mivec....
pls help me..
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
do d simple n easy modification 1st......open port air filter (branded)...whole ekzos system n extractor( 2nd hand branded).....then performance spark plugs with plug cable.......
sports suspension system..........front n reat struct bar...(upper one).....i think over ur budget oledi if included suspension system.....
dun touch internal parts of engine 1st....more expensive.....
make ur car stable so will faster when cornering...it helps when speeding....ok?
tyco263
5
if i want to change my throttle body, can it give my engine more power....
Yong_5290
3,637
49
Klang
hotmail.com
i think theres no such thing as adjustable cam...u mean adjustable cam pulley rite...
wat i did 2 my 4g91 wit cheap low budget...
4-2-1 xtractor...cap ayam rm 100
cap ayam muffler wit straight 1.8" piping rm 200(piping)
4g93 1.8 cam(best is from putra year 97 rm 150
open pod air filter HKS power flow rm 200
dynoed and the result is 106.22hp on wheel at GT AUTO sunway
hope this helps
tyco263
5
this engine when i tarik 1st gear, its very short right and no pickup...
so any comments
alvin24
3,109
27
5,148
Very short means got good pick up lar... else it would've been very long! Hahaha...
I agree with huakenny, basics mods first, then only go to higher stages of mods. Spark plug + spark plug cable i think not necessary though... till now also I still using my OEM spark plug cables.
Suspensions are important too... no point having all that power if u won't be able to use it properly.
RM2500 u should try going for a better suspension setup, then possible a high flow intake filter, extractor and exhaust. Think be then ur 2500 habis liau. Opt for drop in filter, i think better... if u're going for open pod, make sure you do a cold air intake and a heat shield for it.
Yong_5290
I thought your dyno was 106? haha
Yong_5290
3,637
49
Klang
hotmail.com
typo error...106hp on wheel...
2 get this i spend less than 1k...
alvin24...yesterday u in syed arif?
alvin24
3,109
27
5,148
yeaps... u were there also meh?
Yong_5290
3,637
49
Klang
hotmail.com
wow...nice...i also got 1 ported n polished head in my store...no money 2 install yet...heehhe:p
boyzone
2,669
38
5,148
If we put in adjustable cam pulley with std cam , will it work ??
alvin24
3,109
27
5,148
boyzone,
yes it will work... get it tuned properly. Dyno tuned preferably...
menace2society,
why in the world are u hoping to accomplish by putting in that head? If the first place it might not be too reliable due to the bore size difference between a 4G91 and a 4G93... 2ndly the ports might be too big... and 3rdly u might and i think most probably will lose compression.
hi sifus......any help regarding this matter is very much n highly appreciated...anyway,back 2 my enquirie(s)/problem(s)....well...i drive a converted wira (4g63t aka vr4) n many people wld agree n comment dat since its n old engine,d wirings may b obsolete n cause lots of problems...seriously i hope its just d wiring n nothing else...anyway,back to my problem...
1. every morning when i start d car,d engine idles very strangely...d RPM goes up n down like its gonna die off...BUT...after...
