How to make signal LED for side lamp?
miriguy
887
20
Anyone have any ideas on how to DIY signal lights on side mirrors? Im planning to do on a Corolla SEG
TQ
idnawse
205
36
perak
like this ker?
red LED (extra bright)
step 1..dismantle
Step 2..solder LED at PCB
Step 3..drill hole for LED
Step 4..last check and put back all part
Finally after wiring
take about 3hrs++ to finish it ;)
loose_end
3,678
197
Malaysia
Cool..Erm , how about the wiring ?..
idnawse
205
36
perak
tap both wire to fender lamp wire ( green > +ve, black> -ve) wire color for wira fender lamp
wfhan
4,339
96
selangor
how about water-proof ? ain't rain water gonna sip/slip through and wet the pcb and short the circuit ?
miriguy
887
20
very creative bro. i will do that. update this thread soon. is it bright enuf?
nam_s
86
3,008
For your information, you'll need to add a resistor to lower the current or you'll be burning up the leds very soon. How many ohms will depends on how many leds you want to use. For signal lights you can't install it like the pictures because it just wouldn't work or light up the leds. You'll need capacitors and abit of wiring knowledge to make it work. To much to explain in details on the tech as why it won't work. Mainly because of how the current flow on and off (making the bulb blinking). Just remember that LEDs works differently from light bulbs.
miriguy
887
20
thanks for the advice. any step-by-step wiring instructions for dummies?
idnawse
205
36
perak
5 LED i'm using 1kiloohm resistor.. use plastic gum (hot gum) to cover the pcb. so far got no problem. if u use the super bright led..of coz ler bright.. :love:
Bump:
why do we need another wiring for signal? the idea is same like if u change the fender lamp with T10 LED type bulb, it will not blink if u put the LED incorrectly (also same if u change the meter background bulb with LED type),..so if u correctly tap the wire (polarity).. the LED will blink together with signal lamp. plus ..my DIY led signal will blink together with alarm signal.
FYI the LED cant blink if u just touch the -ve to the body... thats why u need to tap both of the wire to the fender signal lamp. (already tested)
ned22am
42
bro those LED connected in parallel rite? n how about PCB? can i get it on hardware store? and if u can show wiring behind the side mirror..:hmmmm:
idnawse
205
36
perak
(+ve)--resistor--anode--cathode--anode--cathode--(-ve) look like this la..izzit parallel or serial? forgot oredi maaa :love: ..PCB? i'm using third brake PCB (recycle..hehehhee) but u can buy the PCB at electronic shop..
miriguy
887
20
hi bro, possible to show pictures of the PCB and wirings?
idnawse
205
36
perak
if wira/mitsubishi...use screw driver/knife/ruler then lever up the mirror only from bottom.
miriguy
887
20
mirror cover shud be able to open. im using corolla SEG. will let u know when im done. now trying to find a good signal cover for the LED.
thanks for the pics bro!:adore:
ned22am
42
thanks bro idnawse.. i try on my motocyle 1st hehehehe..:adore:
Bump: thanks bro idnawse.. i try on my motocyle 1st hehehehe..:adore:
Guys,
As I know Miss Firing System is mean to reduce Turbo Lag, but is it possible for a normal (not Turbo) car to have Miss Firing System?
If Yes, what's the approach to achive that?
Thanks.
