how to install pivot shift light,pls help
Mon_key888
522
Selangor
can anyone help me how to install pivot shift light, i bought this unit 2 months ago and still haven't install because i want to DIY this unit, i need to know the wire connection to my lancer dash board, my car already converted to 4g93t, pls provide me the colour code on where to connect the wire, i can see 4 wire from the unit which is 2 wire for l.e.d, 1 wire for acc and 1 wire for grounding, anybody out there pls help me on this.. :smile:
EVO3gsr
301
this one u hv to remove the key switch there la.... tested wit ur test-pen to which wire is acc....grounding u can direct ground it to body..
go here n see la....beter..hehe
http://www.racingdimension.com/index.asp?PageAction=Custom&ID=2
send to workshop n ask them instal beter la if u not sure
Mon_key888
522
Selangor
gsr evo3
thanks bro, that's really helps, but do you know for acc what is the wire colour code?
huakenny
LB Performance
9,126
240
Kota Kinabalu
tis u hv to test it...
remove ur key switch....open ur key to 'ACC'...then test each wire wit test-pen...see which wire got light ....
if got light.....then to make sure it is 'ACC'...u turn off the key.the light wil gone...then when u switch to acc, then light wil ON...
good luck....
It’s always the Unlimited class vehicles that get all the limelight at Pikes Peak, and rightly so because of their insane power and designs, but if you took some time to check out the other classes, you just might find equally rewarding vehicles that seem to offer just as much fun, if not more.
Take for example Doug Siddens and his modified Polaris RZR buggy that he contests with in the Exhibition...
