How To Diy A Micro Compressor?
First you DIY Money..
Then you Buy MicroCompressor loh.. :) hahah
I DIY PCV air Injectors.
Items :
- Home Cooking Gas Pipe
- T-Joint
- Air Controller Valve
- Small Air Filter (For Motor Bike / Breather)
- Cable Ties
Step :
- Locate PCV pipe
- Cut and add in T-Joint
- Extend the T-Join to Controller Valve
- Add Breather to the end of controller valve
- Cable tie tighly all the JOINTs
Tuning :
- Make sure all joints are tight.
- CLOSE the air controller valve
- Start engine (Idling Steady/Normal)
- Slowly open the valve..
- Engine starts to die.
- Tune it until the engine is stable again, at the same time got air suck in from the controller.
- DONE.
Forgot to add.. Drink 100 Plus..
NOTE : Mine, I replace the Air Breather with Whistle for 'Secret Mod'.. Thanks.
JL sifu.. can show more pics please ? thanks !!
Johnson whats the theory behind this 'micro- compressor' thing. Quite curius about how it works. Thanks
to suck in more positive+ air and discharge negative- air for better combustion...i think
Check out MicroCompressor website or re-seller..
They will give you BEST explanation.. HIgh and Low.
That MicroCompressor website no work larr.
If wira 1.3 carb where is the vacum hose??
My friend did lasttime after seeing another of my friend car got . It's car Air Power. I think work the same as Air Compressor.
Original Air Power was sold at RM160 per piece. This only cost RM4 from kedai ikan :lol:
PCV Valve..
It is on the right side if I am not wrong.
G88,
Yeah.. Your lagendary Air Power...
GOOD !!!
JL, the whistling thingy for ur PCV, stim ar? Bunyi macam itu BOV ar?
Ada lah sikit sikit.. :)
Siok shiok when changing gear, the pressure will reverse.. then can hear.. PPPSSsstt... (very soft)..
haha u guys... i still dont quite understand how to DIY this thing..
what i need? =p
got so many tubes which looks like a vacumm..err.. which wan to connect..? and also err.. what is that thing? hehe... =p
ya !! i also agree !! i wanna do also !! faster set a date !!
hahah TT for micro compressor? =p okok im in..im at Subang jaya
who is going for the sunway DIY session? hmm...
and also gonna DIY this injector? please please please help me buy the stuffs for it? i cant find those stuffs ler.
now i'm looking for the grounding cables also sakit kepala liaos. sigh...
My compresser is fix aready the cost is RM30
hose,valve,T-join=RM15 take from JL
small fillter brand SIMOTA need RM15
DIY time 20minit,but the engine very very hot
But the effect donno yet,how about the FC??
I only heard the sound only,power ++++,donno also,but i feel when changing gear is more smooth aready.
So let talk how about u MC performance??
A Post Every 5 Minutes
