how to adjust air fuel ratio
Apr 22, 2007
anyone can tell me how to adjust the air fuel ratio of 4G15 carb?my car geting only 250km for Rm 50 Fuel :'( too bad fuel consumtion...pls giv me a guide on it thnx ya
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
1) Warm up engine first(run 5-10 mins)
2)Shut off engine
3) Back out on the idle speed screw until it justt doesn't touch the throttle linkage. Then screw it in back about 11 turns
4) Screw in the A/F mixture screw until it stops(do not force tighten)
5) Screw out the A/F mixture screw 2 full turns
6) Start the damn car. It will run like its choking. As long as it's running it's ok.
7) Now turn in the A/F screw until engine dies. If this happens, turn out the A.F screw half turn at a time to bring it back. (try to start the car of coz)
8)Continue to turn out the A/F screw at half turns every 3 seconds. Engine will pick up speed. Continue to screw out until the point engine runs worse. When that happens screw back in half turn every 3 secs to the point engine runs smoothest.(do this by ear or watch engine vibration)
9) Now set the idle speed. Go on the air conditioner. Watch the tachometer. Turn in the idle speed screw until rpm is around 900 to 1000 rpm.
10) Now it's ready to rumble..
vastalux
180
can this method use for injection engine??
sori for noob qeustion...
burnner
1,563
4
hey olcheong,
give us the result after had tune up.
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
2)Shut off engine
Sir Skywalker... I'm noob to carbs
  1. 4G15 for Iswara Auto, izzit the same???
  2. Is there any illustrations for the screws location?
  3. If I can ask somebody to show me where the screws are, does the term screw in meaning clockwise and vice versa?
  4. OK...if I'm a total loser and can't tune the carb meself, how much does it cost to tune it? For that matter, what are the total cost of giving the carbs a full service?
I;m asking this because the mentioned Iswara belongs to my dear mom. I can't bear it to her complained about FC anymore...thanks
Sorry for sooo many stupid questions....
If you wanna know, I'm using Kancil 850Ezi ('i' means injections) as my first and current car...so I'm really 'jahil' abt carbs....
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
1) yes.... 4g15 n 4g13 using the same carb....
2) jeng jeng jeng...
3) screw in means clockwise... similar to water pipe... wanna close the tap (lean mixture), u turn clockwise....
4) the workshop usually tune my carb and ignition timing only charge me 5bucks... other workshop i dunno... but shouldnt be expensive....
ken12292703
Drives a shopping cart...
1,542
8
5,138
SoMeWhErE
Jeng Jeng Jeng... The sifu showing his weapons... FU YOH!
Good information bro... Will the AFR change after some time? Vibration and stuff?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
in normal condition, vr seldom the tuning will run... ur AFR usually getting richer because of ur clogged air filter....
thats also why some installed microcompressor said got difference.... this is because the leaked air in bypassed straight into the intake manifold, thus balance back the rich AFR....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
A thousand thanks......will do it if got time...if not I can just ask mom to send the car to workshop if the pricing like u sez....
now the car at my kampung...
one question thought....
idle speed screw = air con off idle screw?
thanks a mill...especially for the picts...
Hello. Currently, the CA20E engine on my Nissan Bluebird U12 is dying. So I want to swap an SR20DET inside. I want to know what is needed to be done to the ECU, wiring and etc, if the SR might come from the same U12.
Thanks forum.
