Yup, that is why he sending for check up......
bro. eric,
nice meeting up with you. Too rush a time as rain was coming, so did not check on your center ring cone, but the 2 wheels that was re-balanced looks okay. Rim not dented, and tyres also spinning quite round. Only the right side tyre was ran for quite a distance while it was flat as the tyre wording were already worn off.
As mention by "Koh Low" Tall guy in Cantonese, if it still vibrates go back to him then he will check on wheel to test the centralization of the wheel to the hub, and also check on the drive shaft etc.
Hope the balancing was good enough then not need to go back. The 2 wheels were out but 10gms on either side according to his balancing machine.
So far all my cars balanced by him have no problems in vibrations
Still vibrating at 120++
Weird it only started after i changed rims
I think if it keep on vibrating start from 120km/h.. it should not be the balancing already.. it might be some other problems eg, bearings or drive shaft at the cv joint area.. because normally balancing out, if after a certain speed, it'll stable down and wont vibrate again..Start from 120km/h means yes...Last time he mention from 110km/h
He mentioned no problem whatsoever before the rims/tyres change (both second hand ones)
Bro. eric,
You did mention you had the center cone fitted? The one at the center of the hub.
Similar threads | |
P
