How do you guys start your Gtr?
AllenRolex
27
1,503
Dear All,
Just a question.
Depress the Clutch and Start the Engine
or
Start the Engine without depressing the clutch?
Any difference for the above two methods?
V-Spec
1,861
170
5,163
BNR34? Can't start without depressing the clutch one wor.
V-Spec
1,861
170
5,163
Earlie batch tadak?!? :biggrin:
AllenRolex
27
1,503
Probably Nissan did not deploy this system for the first genaration of Bnr34.
As for my Brother's V-spec2, the clutch has to be engaged before you can start.
My Bnr34 V-Spec does not need to engage the clutch to start the engine.
I found that it is easier to start up the car by engaging the clutch first.
Anyone has this experience?
[PIMPIN]
2,138
648
3,213
AFAIK, the earliest BNRs were launched in '99 and I'm sure there are a few guys here that have one. Surely they can confirm if that's normal. It's entirely possible though.
It's basically a safety feature to prevent people from starting the car while still in gear. I have the same car as your brother and if started manually, then the clutch must be depressed but if started remotely then the clutch is bypassed.
AllenRolex
27
1,503
Ya, that's right...
Other than this safety feature,
does it a good practice to start a manual car by depressing the clutch first and start the engine?
Just wanna know the difference...
BNR
144
21
as far as I know... apart from the 'safety' reason, there is no other significant benefit from starting the car with clutch depressed... so? just crank away!!
[PIMPIN]
2,138
648
3,213
Ya, that's right...
Well, I guess so. It's probably better to make it a habit of always making sure the car is in neutral regardless of whatever safety features the car comes with. Make it part of your routine - enter car, immediately lock doors, check mirrors, put on seatbelt, make sure the gearstick is in neutral and then start the car. :burnout:
AllenRolex
27
1,503
Thank you guys for the comprehensive information shared here...
Gtr rocks...
farizio
482
37
First gen BNR34's didn't require the clutch to be depressed to start.
Only when the Vspec II model was launched in August 2000 did they incorporate this into all their cars
In short, if you have a V-spec/Standard spec with grey interior, you wont need to press the clutch.. but if it has a black interior, you have to press the clutch to start
[PIMPIN]
2,138
648
3,213
So it's like the Subaru as well; mine needed the clutch to be depressed as opposed to earlier ones. They should make it a standard feature on all manual cars.
NeniNeniBoBo
377
34
1) Key-in turn to ignition I.
2) Check all lights appear.(eg:abs,engine, a-lsd,4wd and bla bla bla)
3) Wait until ABS light disappear, then press clutch pedal and turn engine ON.
*My car engine can't start without press clutch pedal, my car model is BNR34 V-Spec2*
Good day,
Another Volkswagen need to update here. This car is a brand new 1week old ride, owner wash this car by himself with plain water after he got it. During inspection this car have only 15% of swirls and other than that is RIDS that may need wet sanding to remove. We cant expect the car will be in perfect condition once you got the car, even a BMW will have hologram issue once the owner got his car at the showroom.
The Jetta was delivered to me on Friday, weather was bad too...
