Hotbits or GAB suspension for Kia Spectra?
LemonRuski
203
Hi all,
I'm looking for new set of absorbers & spring for my 2004 Kia Spectra. I understand that RS-One sells GAB suspension (HA series) for my Spectra.
Also found out that Hotbits has suspension of my car too.
Need advice. Based on your experience, which would you recommend ? Hotbits or GAB?
Thanks in advance....
dennisdreams
333
21
GABs, live longer and easier to service. hot-bits will be going into the rubbish bin once it's inner wall wears out(usually about 90K~100K-km service lifetime).
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
imho,go for hot bits.a lot better then gab.on dennis comment,well,other suspension
will be in the dust bin too if the inner wall wears out.my 2 cent.:biggrin:
dennisdreams
333
21
true GT_auto, other suspension will go into the bin too if the inner wall wear-out. But, as long as it's a twin-tube design, it's possible to replace the inner pipe. Gab as far as i know, for it's standard model which is non-body hight adjustable. is using twin-tube system. which is serviceable.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
my problem with gab is their built quality to be honest.i don't find it to
be up to par with other brand that r locally assemble.
dennisdreams
333
21
lol~ agree on that. i also found out that HWL had better build quality of all locally made adjustable. hot bit if fine for it's build by big factory, but fall back with his short service life.
Ride&Handling
136
TEIN - Fully adjustable and fully serviceble. even the inner valving can be service, oil can be replace and pressurised gas can be refilled..
dennisdreams
333
21
hot bit... expensive stuff with their "germany" tech-brace. but in tern of service life, it's short, around 3 years or 60,000km. i had seen more retired hot bits which been used about 3~4 years than tein (japan, not local) up to 5 years without needing servicing (local tein need to be service every 2 years and it's seals would last about 5 years on good care).
cit
8
i think tein more better
go for tein
install tein hr21 for kia spectra
dennisdreams
333
21
HWL had not a bad heart. It's about the same as Tein (Malaysia), but just need a few twick will set it right for your car ;)
I want to put extra fan in perodua kenari,i dont have experience in it at all,i want to ask the wind should blow inside the engine or blow it out?and i want to wiring it to the compressor,so when i turn the aircond the fan also spin,can everybody teach me how to jump the wire to the compressor while using the relay
Sent from my SM-N9208 using Tapatalk
