Help Needed...Cant cure my Evo3 engine..
zarique
203
Penang
bro sifus and masters of 4G63,:adore:
my engine timing belt putus so i rebuild another engine...
diesel 2.2 blok with 1jz piston (piston rings in good condition)...
replace head gasket with custom metal 1.8mm...
using same old Evo3 head with bought used valve...
all valve were grind and valve seal replace new...
the blok were skim and bore bit...
after installed, there seems to be white smokes coming out from the exhaust...
why?
my mech rechecked, the turbo not berasap...
but what he found out was
1.there are no oil on top of the piston...
2.but there are oil on the exhaust valve...
3.no oil at the pungkok turbo(turbine)...
what is the problem i'm having...
anyone that mayb have experienced the same thing before...
pls help me out...i missed my car...
so long didnt 'tarik'...hehehe...:driver:
zarique
203
Penang
if top cylinder promblem means
wut should i do...?
thanks bro for the info...
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
when your timing belt "putus" most likely your cylinder head is already dead... no point changing just the valves. get another known good condition evo3 cylinder head would be your best bet to resolve your issues. a diesel block may not have the same oil passages as your evo3 block... recheck the oil passage..... unless this "rojak" has been done b4 and proven to be ok...
i'd place my bets that your cylinder head is the culprit.
celikancil
347
maybe ur mech tak tutup lubang return minyak kat block tuh.....
or if ur block already polished, when cold memang ader asap putih, but when engine in work temp, the smoke akan hilang...... magic kan???? hehe...
<a href="http://www.zerotohundred.com/newforums/showthread.php?t=136125"><img border="0" src="http://www.zerotohundred.com/features/tokyo_auto_salon_2007/part_2/hall_1/cars/banner.jpg" width="250" height="75" alt="Tokyo Auto Salon 2007"></a><br><b>Tokyo Auto Salon 2007 Part 2 - Live Coverage | New Concept Models</b><p>New turbocharged BMW E90 335i being the latest BMW 3 series coupe a big hit<br>&nbsp;in Japan. It's already setting the standards in the sports coupe industry in...
