does safc cure & solve idling problem?
ettk2003
141
hi guyz,
need some advice...my car has some idling problem...the rpm meter drops to very low...sometimes feel like its going to stall, especially when i on the air-con...sometimes it really stall...
have done almost everything, changing stuff and so, its ok for a while but problem comes back...
sometimes ts running ok, the rpm is at perfect level, thats what makes it hard to adjust...
im driving a turbo car...so was just wondering whether if installing safc can help solve this problem...anyone tried?
thanks in advance for the help and advice....
jinkl-
552
Klang
r u on MAF ?
r u recirculating ur BOV ?
r u using standard BOV ?
if aftermarket BOV , is it tight enough to prevent leak ?
is ur ISC ok ?
ur throthle body clean ?
ur vacuum hoses no bocor ?
check ur breather ok or not
ziranath
211
bangsar,kl
your throttle body kong already la bro..either service or change it.my mech seperate the a/cond valve(dunno the real name).he tebuk my throttle body to put that valve.
ettk2003
141
thanks for the advice guys....
hmm...maybe vacuum hose leak...im using silicon hose...is the original hose better?
yup...i hav MAF with hks ssqv bov...could that be the problem?but have been using it for a very long time...
i hav just change the throttle body, so i dont think that is the problem...the rpm was prefect after i changed...if its the throttle body then the rpm will go crazy, like high low high low...especially when the air-con is on....but mine is good...its just that the rpm stays very low with or without air-con
Hi guys,
I need help from you guys. I'm trying to find 2nd hand woofer or sub woofer and CD + MP3 player. Can you guys help me on that?
Thanks,
Regards,
ajis2040
