Was walking around with my mum in this plastic store,
saw a nice item to be made into heat shield,
rm4.90 , dustbin , use a saw or cutter, n that all it was needed for
a 6" open pod , here are the pics , the front opening of the filter meets my cold air intake
when you install a heat shield make sure u still have ambient air that can reach your filter easily. I have seen some heatsheilds that cause more harm than good by limiting the circulating air around the filter.
If you have a cold air intake then it should be good to go already, if not then it is going to be pretty restrictive.
I just use a sunshade cut it out and cover it around my open pod.
I agree with mokomoko. I used to use an open pod that was encased in a cylinder type of carbon fibre casing as heat shield. I felt it couldn't suck in enuff volume of air. When I change it to Apexi open pod, I could instantly feel the difference.
damn!!....what the F**K!! my car got smashed at the drivers door glass and my rsm and turbo timer is gone. blardy f**kers!! it happened like around 8-9am in the morning. my hsemate who went out at about 8am said there was nothing at that time..when he fetch his sis to mid valley and then back....gone! saw my car wind shield smashed liao...........happened at my HOUSE!!! DAMN!!! house at ss2/81, the taman opposite ss2 murni. i just hope those low class assholes will die a damn painfull...
