What car? I'm driving Persona Elegance. Drum brake is sh*t.Yeah its a drum brake.. Thought of changing it to disc but the shop I went to couldn't quote me a price
OKAY. Time to take out the console and check.....when there is time.pull handbrake there must be indicator on at ur meter cluster.. tap from there la. Or u need to reverse the signal fm handbrake switch fm -ve to +ve in order to trigger the relay (i'm not sure if relay can trigger by -ve signal..not too expert in electrical knowledge). AFAIK handbrake switch is ground signal. For me thats better rather than to open the meter cluster and tracking the indicator wire 1by1.
Steel braided does not increased the brake's bite rate but it works in the way you got no flexing on the hoses when you jam the brake, thus, make it more responsive. I actually DIY masking the stock brake hose using cable tight and it works just like steel braided. Only problem is its a plastic so it only lasted a few months.Change to steel braided brake hose?
Everyone says its effective?
I need to change mine too.
I saw prices are rm300 but dunno is 1 set or what.
Yeap. I understand it's purpose bro.Steel braided does not increased the brake's bite rate but it works in the way you got no flexing on the hoses when you jam the brake, thus, make it more responsive. I actually DIY masking the stock brake hose using cable tight and it works just like steel braided. Only problem is its a plastic so it only lasted a few months.
RM2xx and above pricing are for 1 set consist of 4 braided hose line. You need to remove the wheels for installation.
Well, i do it on the 4th brake light only?frankly speak, I don't find this idea is practical. Brake light could be irritating to the driver behind you. not a good idea
Whether drum or disc brakes, if the hand brakes are not tuned properly, the brakes don't bite therefore you can still drive with it on. It tuned proper the resistance can be felt, then you know the brakes are on....Your's must be drum brake? Since u can drag it all the way.
Wuu this is something. So when the pedal is pressed, it's 21W right?
There's a few proven brands now, Improve (I'm using this), superstreet, BFGoodridge and RSPro (Or was it Pro RS?), anyway the key point to a long lasting steel braided hose is cleanliness. You'll want to remove mud, tar and whatever that's stuck on it or coating it.Yeap. I understand it's purpose bro.
My PE now is very bad. Plus, i have a small brake pump.
I know one brand is good bit what about the others?
what's the difference? I cant find it.
Roger. Thanks. Improve seems cheaper than other brands like Pro RS.There's a few proven brands now, Improve (I'm using this), superstreet, BFGoodridge and RSPro (Or was it Pro RS?), anyway the key point to a long lasting steel braided hose is cleanliness. You'll want to remove mud, tar and whatever that's stuck on it or coating it.
Yeah. The theory is we want to avoid getting dirt and all stuck between the braiding cuz if it does, it weakens the braiding and that'll eventually lead to a leak.Roger. Thanks. Improve seems cheaper than other brands like Pro RS.
Then everytime u wash your car, u clean the hoses too? :o
