Enquiries preventing the block from warping.
pupylogyEG6
123
hi sifus!
Just recently i have just screwed up my engine. I'm using B20 block, B16 Head, Block guard, Wiseco 86mm (high Compression),and a Ngk spark plug. The Block are over heated without notice, the piston was ok still however the block has scratchs on the both side (not the inlet and exchaust) of the stoking path. at the bottom of the block the piston stroking area are warped and runs 1mm of the daimeter.
So Sifus, are they anyway to prevent that from happening again? Your advice is much appreciated.
Thank you
mdsb3
130
nice mod bro..what ur cam d u use? dyno how whp?
possible cause
1.low oil pressure
2.engine overheat
3.crank vibrate
4.rod bearing burn
no guarantee when u already mod ur engine
best way dart wet sleeve.
sorry just my opinion only.
I'm looking for lambo door conversion kits for my car everywhere in penang and BM.
does anyone know where i can find it in malaysia?!!?
Thanks
