- Nov 17, 2005
- 1,187
- 112
- 1,663
Hey guys,
Whenever i'm reversing or on first gear but pressing and depressing the clutch it feels as though the engine is juddering or gearbox. Well it's like this. You are reversing but going slowly because of a bump behind you so you press and depress the clutch and accelerate slowly. Then there is this judder. Kinda of bad that the engine is rocking or probably the gearbox. Any ideas? Could it be the engine mounting? Clutch? It does not happen is I on other gears. Sometimes when that happens i just slot into second gear(straining the gears) and the problem disappears. Hope you guys have experienced this before and found a way to correct this.
