Engine Judder
turbolover
1,187
112
Hey guys,
Whenever i'm reversing or on first gear but pressing and depressing the clutch it feels as though the engine is juddering or gearbox. Well it's like this. You are reversing but going slowly because of a bump behind you so you press and depress the clutch and accelerate slowly. Then there is this judder. Kinda of bad that the engine is rocking or probably the gearbox. Any ideas? Could it be the engine mounting? Clutch? It does not happen is I on other gears. Sometimes when that happens i just slot into second gear(straining the gears) and the problem disappears. Hope you guys have experienced this before and found a way to correct this.
turbolover
1,187
112
are u using 3/4/6 puck clutch?
suspect your gbox mounting.....or could be the clutch bearing.
I'm kinda noob although I have been driving turbo cars for like a few years already. It's on a Exedy racing clutch but not sure how many puck. I didn't ask the owner. Should I?
DanzEterna
15,910
3,371
www.primeperdanaclub.com
how long u used the clutch edi?
should be 3puck.......if not mistaken.....thats always the common problem with racing clutches....
get xtemeleo to help u diagnosed, he knows.......
turbolover
1,187
112
Hmmm maybe that's the problem? Hopefully and nothing serious. Yes, xtremeleo is really helpful. I pm him a dozen of questions and all was answered. Well if he does not come across this thread then I will pm him.
turbolover
1,187
112
yup hopefully nothing serious.....
check your mountings 1st, especially the gbox ones.
if everything ok should be the clutch.
Could it be the clutch that is worn out or it's just basically the poor design of the clutch that causes judder. 1st gear off the lights no problem. Only in slow moving traffic or start stop moving only.
mitsu4G
229
Johor Bahru
bro..i think it is time to change yr clutch..i've been encountered dis kinda' problem last time..aftr changing the clutch, problem solved..no judder or serious vibration while in 1st gear or reverse gear...wuteva it is, go n hv a check 1st bro..
turbolover
1,187
112
Faulty clutch or worn out clutch?
mitsu4G
229
Johor Bahru
faulty clutch for me is when u step on the clutch pedal..not even full step, it wil make like 'grinding sound'..n its very very hard to engage to any gears..happened to me with my twin plate before until my mech have to take the car from my house n drive it to his w/shop only using 2nd gear all the way..real bad..
turbolover
1,187
112
Hmmm seems like I have to bring to an expert. My clutch does not seem to slip.
DanzEterna
15,910
3,371
i think the clutch bearing already mkn badly.......grinding sound normally if u using racing clutches that have screws at the end of the pads.....once the pad habis edi, then will makan the screw......
like works...that time u may need to skim your flywheel.
but exedy ones dun have....they glue it down to the plate.
turbolover
1,187
112
Glue it down? Can hold ah with the friction and heat generated from the clutch plates? Aiyo mine don't have such symptoms don't know how la.
turbolover
1,187
112
Yup have seen it before but it did not occur to me it was glued. Those bloody epoxy sold in the hardware shop can't even stand heat. My mech once used epoxy to seal my automatic gear box which was crack though. But that one hold up pretty well. Not sure whether the gearbox at that part was hot or not. Maybe the one I bought was imitation. Hehe.
peterj
1,321
258
1,683
Kuching
get used to racing clutch, it needs technique to control well on street... since it is not for street used, stated clearly on the package.... but i use exedy racing clutch too and i used to it and learnt how to control...
mitsu4G
229
Johor Bahru
that is exactly wut had happened to me last time wit my twin plate..at the moment using stock clutch n flywheel je..huhu
turbolover
1,187
112
The thing is not whether can control or not. The more I prod the accelerator the worst the judder eventhough I have not release the clutch fully. Off from traffic light whether launching or normal release clutch no problem. Problem only happens when I release clutch then press clutch then depress I will feel the judder.
Will worn out clutch plate have this symptom?
A Post Every 5 Mins
Break free from traditional ****** norms and embrace the best in casual connections.
Secret meetings, forbidden desires for the night
Genuine Females
Super casual ******
