Double Signal with Switch
ryukeong
96
Hi there,
Does anyone know how to do 'Double Signal' that will stay on (Front & Rear) with switches to control on/off. And it will still blinks when u use the signal.
SkYwAlKeR
10,139
300
ePoh ~ malacca
try use the search button.... i guess we had discussed this numerous times already....
if u wanna save the hassle, ask acc shop to do it lo... shouldnt cost u alot since it is done by tapping some wires.....
ryukeong
96
Redline_club said:
sure got le, now our signal bulb is 1 leg ma, brake bulb got 2 legs, i do it at my wira...
You got installed it with switch too?? Izit you diy or do at acc shop? How much u had used to get it done?
cacin
1,000
5
5,138
IMHO, if you wanna do this, why don't only use the side signal? If you use front and rear, people might misunderstood you thinking that you want to take a junction or change lane. They might think that your signal is broken (since it is not blinking). Imagine if some one is coming out of a junction and saw your front signal to the left Or both is on, he might just come out of the junction and bad things can happen right? People might also assume you're switching on your hazard light and try to overtake. Normally, hazard light is on when the car is stationary (due to failure etc).
Redline_club
892
www.redline-club.com
wont de, hazard on in low le, whn we put signal it will blink, kl many ppl do le...
howiechoo
8,000 RPM
8,857
Bukit Jalil
seriously, it's dangerous...they do tat cos they are noob about wat is signal light...so do u?
ExceL
1,726
162
Ampang/KL
That dosent make it legal or right.
When you drive, you dont stare at signal light of the car in front of you. You just glance at it, and act accordingly. I'v encountered some of these cars before, it can be very dangerous and sometimes not at all.
howiechoo
8,000 RPM
8,857
Bukit Jalil
if u do then y u wan to sue the signal? just teke it off lor..hohohohoh
I had some questions here, I heard from most exhaust shop, which tell me auto car must maintain certain level back pressure(flow velocity).
But some says auto tranny need as much back pressure as possible to get the best fc and pick up:hmmmm:??
My current exhaust set up was
4-2-1 - 1.6(piping) - 2.0 inlet straight flow long type muffler - 1.75 straight flow ( hotbits ).
The reason I using straight flow, because when I was asking the open pod method with speedwork, they ask me to do...
