DIY Scramble Boost Controller
Jun9970
37
Dun flame me, i'm a noob + i haven't come accross anyone who has done it yet.
ANyway,
After looking at the GFB boost controller, it dawned upon me that it might be do-able for less than RM200. ie two preset levels of boost (ie stock n high).
How does it work?
For certain mitsubishi fuel injection cars, the air-cond idling valve is moounted on the throttlebody. After some time it tends to fail. This results in the car dying off when the air cond is on during normal driving (especially during gearshifts). Instead of trying to replace this valve which can be costly, mechanics often use an auxiliary solenoid (FICD) to compensate and circumvent the faulty stock unit. It costs about rm200 n is manufactured by Nippon Denso. What it actually is, is a simple magnetic solenoid which allows vacum or boost to bypass a valve. it has a knob on it 2 control the amount of vacuum or boost n is usually wired to the air-cond compressor, triggering when the compressor is working.
Can we plug this in between the turbo actuator hose (ie same place as a manual boost controller, fish tank valve) n wire it 2 a switch in the passenger compartment?
works based on the same principle as aftermarket boost controllers, whereby it allows boost 2 leak, thereby tricking the turbine wastegate actuator into opening later n hence creating a higher boost.
feedback pls. Thanks
sylver'sAD
207
i think the one u mention might not can handle the pressure..
it also only controling the amout of vacum but not the pressure..
(correct me if i'm wrong).. u can find variety of solenoid valve and pressure controller at the mechanical shop..
as for me.. i'm using 2(the cheepers) air flow valve to control the valve..
one is for stock and the other for the gila boost... theheh... and using one switch in the middle of those.. theheheheh... left stock,right gilaa one...
don't shoot me also.. i'm new also.. and with low budget...
:D :D
sylver'sAD
207
aiyaa... i don't afford to buy digital camera la.. also no money to buy the camera handphone...theheheheh... but ..i'll try..
sylver'sAD
207
hurmmm...but need money for raya lor...
sylver'sAD
207
theheheh...who sez so... got 2 kid already.. wife also want new cloth..
new interior somemore.... huh...my hair is going to botak already..
Well known graphic designer Jon Sibal came up with these renderings of the Mclaren MP4-12C GTR. He used several different classic liveries like Fina, Gulf and Marlboro. It's unlikely that the Mclaren MP4-12C GTR will ever be adorned in these liveries, in fact we don't even know if the MP4-12C will be competing in races (though we have absolutely no doubt that Mclaren will contest the car), but...
