Tools:
1. Socket bolt size 8,10,12,14,17
2. Ratchet and long extensionbar
3. Ring spanner size 14
4. Extra bolt to tighten back engine mounting stud
[*]Do this DIY at ur own RISK, Do ur own research before dismantle.
[*]Make sure you have all appropriate/Proper and QUALITY tools
[*]All Bolts should be hand tight first before using ratchet to avoid bolt thread strip
- Jack abit at the oil pan to support the engine
- Dont jack kaw kaw, later oil pan crack it's ur problem.
- Don't use hydraulic jack like i did because ur hydraulic might spoil.
- Remove All Black,Blue and Green Bolt
- Blue Dot Bolt Size 14
- Black Dot bolt size 12
- Green Dot bolt size 17
- All Bolt are out
- When installing the engine mounting back, the Bolt on the green dot should be easily tighten back. If u feel hard to fit in, jack up the engine a lilttle bit more.
- Let say u want to change engine timing belt upper cover
- Remove all three bolt size 8
- The stud came off with the bolt jus now
- Use the 2 extra bolt, tighten the stud back
- Reinstall back everything in reverse order.
- The Endddddddd
