Features
6.2" HD with FRONT & REAR CAMERA Function
Full Interactive Graphic User Interface
DUAL ZONE FUNCTION with PIP feature : Playback two souces at the same time while the GPS is still activated. Now front and rear passengers can pick their own entertainment.
DVD/VCD/MP3/CD-R/RW with ID Song Tag & ESP
FM 3-Band with Superb Reception FM Tuner
Automatic memory Preset Storage Function
Disc Scan/Repeat/Shuffle Play with track search function
Real-time Clock Function display
Electronic Audio (Vol/Bass/Treble/Balance/Fader) Control
Present EQ (Pop/Rock/Classic/Jazz/Flat)
4 x 50 Watts Maximum Output Power
Low-Impedance RCA Line Out Plugs
Auto NTSC & PAL Color System Switching
Compatible with iPod/iPod Nano/iPhone
iPod Cable (Optional)
GPS Navigation (Optional)
Built-in Memory Card Slot
Built-in Multi-System TV Tuner
Built-in Bluetooth
Specifications
Size: Toyota Vios OEM / Factory Fit
Screen: 6.2″ High Definition TFT LCD screen with 800×480 pixel touch-screen panel
Disc Type Support : DVD/DVD-R, DVD-RW, CD, CD-R, CD-RW
Supported Audio Formats : Audio DVD, Audio CD, HDCD, MP3
Supported Video Formats : MPEG4, DivX, DVD, SVCD, VCD
General MP3 with 100 sec Electronics Anti-shock Protection
USB 1.0/2.0 Compatible
Remote Control : Yes
Connectivity: Bluetooth, USB, SD card, Auxiliary input
Supported devices : Ipod (via Ipod cable), Iphone 3, Iphone 4, Android, Blackberry & most common devices via
TV tuner : Built-In
AM/FM: Frequencies for all countries, with RDS
Reverse Camera Input : Yes
Front Camera Input : Yes
GPS : Add-on available
Power Requirements : 11.5~14.5V
Load Impedance : 4 ohm
Tone control : ±8dB (Bass 100Hz, Treble 10KHz)
Mounting Dimensions : Approx 178x100x183mm (dxwxh)
Weight : Approx 3.2kg
Power Output : 45W x 4 (8ohm)
Mounting Angle : 0 -±3°
I/O Interface
FM/AM Antenna Input x 1
TV Antenna Input x 2
Aux Input Slot x 1
USB Input Slot x 1
SD Memory Card Input Slot x 1
DVD/CD Reader Input x 1
Video RCA Input Terminals x 2
Audio RCA Input Terminals x 1 Pair - Left & Right
Video RCA Output Terminals x 2
Audio RCA Output Terminals x 2 Pairs - Left & Right
OEM ISO or Toyota Head Unit Connector
iPod Connector
Purchase and have it delivered to you 12 Volts - Malaysia's Premium Car Audio, Accessories & Parts Online Store : Carvox Vegas Toyota Vios Silver OEM Plug-N-Play 6.2 inch HD DVD Player (GPS Upgradable)
