Car follow the road surface
shaharel
129
Dear All,
One more problem I just encountered is the car like to follow the road surface. Why ar?? Done the chamber + wheel alignment still the same.. Anything to do with bushing? But can't hear any sound from the bottom of the car during driving.. Or is it something to do with the steering rack?
LittleWhiteWagon
1,656
187
P.J
Odd...
What tires tramline anyway? Never encountered those before. :hmmmm:
shaharel
129
Huh.. means no solution? I'm using Yokohama A-Drive
ir1z
102
4
like to follow road surface?? how low is your ride now shah?
by the way lets meet up this march in kertih/paka if ur free. Ill be auditing there during that period
Barbarian
625
24
www.myjsoc.com
Odd...
high performance, low profile, wide tires are more prone to tramline..... you can try googling and reading up on it.....
shaharel.... you can do much about it till your next tyre change...... :driver:
shaharel
129
Actually I just changed my tires 3 months back and still thick till now due to seldom drive. If I would change the tire, what would be your recommendation (not too expensive tire) and what is the size like?
---------- Post added at 11:39 AM ---------- Previous post was at 11:39 AM ----------
March?? Still long time to go.. :wavey:
Barbarian
625
24
www.myjsoc.com
did you notice this tramline issue only after you change tires? if it doesn't bother you much then just stick with it for a couple of years lor....
tire choice depends on your priority... what do you expect out of it? peformance? quiet? comfortable? cheap?
shaharel
129
Before change tire, got a little.. After change, worst.. Try to do alignment + chamber also same.. no solution..
Maybe will check as per lan evo advise 1st & see.. Maybe next week when I'm back to KL
shaharel
129
Checked everything and all fine.. Problem still persist! I think should be the wheel size.. that's what all mechanic says also..
ir1z
102
4
is ur problem solved now?
shaharel
129
not solve.. still kacau.. as of now, just pretend that there is no problem.. haha :biggrin:
