Car battery charger to MAXIMIZE battery power and performance!
Car Culture
Selangor
The world’s most advanced and versatile motorcycle, car and boat battery saving charger, maintainer and tester. It’s a durable, portable, easy and safe to use battery first aid to maximize battery power and performance
Extends and optimizes battery power and life by up to 400%!
OptiMate 6 will maintain your battery safe and ready-to-go for months on end, with the extremely effective “charge and rest” maintenance program that will keep your battery at its optimum level of performance, giving your car electrical systems the power it needs to run at optimum as well. Your battery will perform stronger and last 4 times longer
Maximize your savings by maximizing your battery life! The longer your battery runs, the more you potentially save, especially if you have more than 1 car at home
Saves the battery you thought was dead! OptiMate 6’s proven multi stage desulphation program saves and recovers neglected batteries other chargers can't.
Gets the rated power out of your performance battery! The unique "Ampmatic" microprocessor automatically selects the best program and adjust the charge current each time you hook up a battery, guaranteeing the fastest and most complete charge. The cell voltage balancing mode optimizes the battery performance and will also correctly prepare a new battery for first use.
Warns you of battery problems with unique test and maintenance cycle! Daily battery condition tests monitors the battery and the current drain by the vehicle circuitry; a problem is indicated on an easy to understand light display, enabling you to take preemptive steps.
Ampmatic current control: 0,4 – 5,0Amps. Optimate 6's unique Ampmatic processor is able to find the best way to charge your battery, automatically. Depending on the condition of your battery, it will run different charging processes in order to restore your battery
Recommended for STD (with removable filler caps), sealed AGM (absorbed glass mat), sealed GEL and spiral cell 12V lead-acid batteries up to 240Ah.
Fully automatic operation that includes all safety features such as reverse polarity protection, no spark connection.
3 year limited warranty.
"Reply Ad" now to MAXIMISE your SAVING and your BATTERY LIFE!
No modex, you plug the charger into your house electrical supply, and hook it up to the battery leads to charge/maintain the battery.
