MirageAsti
My boost used to be 0.8, now by the looks of it, only 0.6.. 0.7 spike then drop to 0.6 bar. What can be the cause?
Just done making a screamer pipe just now. Boost back up to 0.8 lol. Backpressure problem?
Actually kind of overboosting to 1.2bar right now.. Screamer pipe normal problem..
In my case I set the boost to 1 bar and when I boost, the meter shows more than 1 bar..
It goes more than 1 bar like 1.1 . why is that so ? and I get some backfiring after boosting kuat sikit .
Hadi, think thats normal. It is called boost creep. Its the nature of your wastegate spring. If you use electronic boost controller, this creep can be minimised. Not very sure bout the backfire though. If not mistaken, mitsu ignition sys is wasted spark. Sometimes you get this kind of pop sound when gear changing in normal manner. Not tarik time. Think so...
Similar threads | |
