BC V1 Coilover [ZC31S}
dem0nel
dem0nel
May 18, 2014
12
503
Singapore
hi everyone,
i wanna ask all BC V1 coilover owner. Do you....
* feel bumpy even on straight road with hard setting (I am feel like riding a horse now)
* have soft weird squeaking noise (like rubber rubbing on each other)
* have a one weird knocking sound when full right steering turn
i am experiencing all the above on my 2007 swift sport , sound from front right.is it faulty and gone case?
what setting are you currently at for front and rear?
Are you using BC spring 4KG / part number 62.180.004?
thanks in advance
beatnik
beatnik
924
74
3,028
Newly installed?
sounds like your rear springs have too much preload. do you have pics of your rear setup? (both, when the car is on a ramp and at rest (under full compression))
dem0nel
dem0nel
12
503
Singapore
Newly installed?
thanks for your reply.
my issue solved due to max on both F & R (my itchy finger).
i send to my mechanic and he took my car spin one round came back, set to 25F 18R.
currently not as bumpy as before, no sound when moving off.
haven't tried u-turn for knocking sound (will update soon).
***UPDATED***:
U-Turn do not have knocking sound anymore, will keep a look out further.
still hear slight squeaky sound from the front right side when moving off & normal cruise speed
---------- Post added at 07:07 PM ---------- 6 hour anti-bump limit - Previous post was at 07:05 PM ----------
btw i heard that no matter what setting you are at.
BC V1 is a bumpy coilover in default, just a matter how bumpy it will be.
unless change to other brand :laugh:
GEFORCEXTREME
GEFORCEXTREME
151
13
Actually, by bumpy, do you mean harsh ride or bumpy? Bumpy (up and down like sampan) is caused by insufficient damping rate which means the damper is set to too soft compared to the spring that you have. On the other hand, by harsh, it probably means you have the spring is to hard and damping set to too hard/high for your car. So which is it?
dem0nel
dem0nel
12
503
Singapore
Thx geforcextreme for replying
My bumpy means like I riding on a horse (up down) on straight even road @ 30F 30R by my own itchy hand setting.
Right now on 25F 18R setting done by mechanic, it feel much better than earlier. But still feel slight bumpy on straight road though within my acceptable "comfort" zone. the spring that come with BC V1 is 4KG type in default. I have checked with other fellow BC V1 users, they also told me is bumpy on theirs too.
Lastly pertaining to the rubber rubbing squeeky sound came from my front right side. Under this new 25F 18R setting, it no longer obvious but at times can hear slight sound off when in normal cruzing speed or move off speed.
I am not sure what else to do..it getting on my nerves too. Prolly I change to other brand or move to non-coilover . Maybe you can share more insight and advice for me . Thanks
beatnik
beatnik
924
74
3,028
Like i mentioned, you probably have too much preload.. or wrong setup at the rear, causing your shocks riding on bump stops rather than springs to control the oscillation.
post some pics of the coilover on your car. lets see if we can sort it out.
dem0nel
dem0nel
12
503
Singapore
later i try take some pics and upload here
---------- Post added at 07:25 PM ---------- 6 hour anti-bump limit - Previous post was at 06:36 PM ----------
***UPDATED WITH PIC***
---------- Post added at 07:40 PM ---------- 6 hour anti-bump limit - Previous post was at 07:25 PM ----------
height adjusted pic
Front 1 finger gap / Rear 1.5 finger gap
GEFORCEXTREME
GEFORCEXTREME
151
13
I think your bumpy means harsh or stiff ride. It's normal for coil overs especially if you set it to max hard. You will feel all the imperfections of the road. Some ppl call that better handling, but others don't like it because it is uncomfortable. Changing to another brand probably won't help much. BC racing is a good brand, just spend more time adjusting to your taste, instead of making it hard, maybe go the other way.
dem0nel
dem0nel
12
503
Singapore
Thanks once again geforcextreme
Yeap now I m on another setting 25/18...
Maybe next week I try 25/20 like other zc31s recommended me
Only thing now is the sound from right front coilover is irritating probably it a sign of replacement
GEFORCEXTREME
GEFORCEXTREME
151
13
I don't think it's because it's hitting the bumpstop. Bumpstop are hit when the damper is soft and you have exceeded the stroke of the absorber. Too much preload means you are compressing the springs and that will probably make hitting the bumpstop harder.
dem0nel
dem0nel
12
503
Singapore
any recommendation as in i should go softer than current like 18/20?
what if i change the spring?
beatnik
beatnik
924
74
3,028
your rear springs look fine. none of them are binding.. how is the front springs being set up? the upper perch should be adjusted in such a way that it holds the springs without tension when the car is jacked up. springs should be snug enough without freeplay but still allows the spring to rotate. if you can't turn the springs using your hand, most likely the springs have too much preload.
that's on the installation. assuming front and rear installed ok, it is just a matter of playing the soft/hard settings. adjust as you like..
but if it's still bumpy, then probably the BC doesn't give the ride quality as you expected.:driver:
dem0nel
dem0nel
12
503
Singapore
let me try with car jack up & turn the springs like you suggested. check for preload
i will further adjust and fine tune to my "likeness" after checking the preload thingy
currently with the new setting 25/18, it much less bumpy though still experience it at certain moments but within my acceptable range. consider case closed here.
my concern now is the squeaky sound problem still persist from right front, moving off & cruise speed
have slight squeak sound. Someone told me to get my shock suspension thrust bearing and mounting check immediately. also maybe send in to service the right piece damper that giving that stupid noise as well.
beatnik
beatnik
924
74
3,028
in the second pic, the springs doesn't look 'straight'.. and maybe just camera effect?
dem0nel
dem0nel
12
503
Singapore
good eye sight...i noticed it but keep quiet see anyone reply :biggrin:
this is the right piece that giving off the sound / knock earlier.
someone told me usually the squeaky sound main culprit is damper. And BC V1 can be serviced with a small sum fee of SGD$150.00 (RM375) by the distributor in SG.
dem0nel
dem0nel
12
503
Singapore
latest update...
i reset again myself from 25/18 to now 20/18, smooth ride, no more bumpy, taking corners so far so good.
squeaky sound remained still as before, need to send in for check asap.
full lock right turn, no knocking sound anymore never heard of anymore since the first reset 25/18
i mostl likely to change front spring to 6kg (since one of them looks crooked) while i remained 4kg at rear
or anyone know the default front spring comes with BC V1 is how many kg?
beatnik
beatnik
924
74
3,028
ZC31S
Front: 62-200-5 = 62mm diameter, 200mm length, 5k stiffness
Rear: 62-180-4-S = 62mm diameter, 180mm length, 4k stiffness
Jose
Jose
243
36
Subang Jaya
I'm using BR series on my Swift Sport. Surprisingly it's more comforting than V1.
Thread starter Similar threads Forum Replies Date
S Car Talk 28
mydaus Car Talk 8
Y Car Talk 0
Z Car Talk 9
