B16A Engine OIL
TheSquee
448
12
518
My b16a is facing white smoke at start up , just a puff of white smoke.
spark plug covered with engine oil
right now using mineral oil 20w50 bardahl.. any suggestions on something similar to use ?
maybe 15w40 ? worried i burn oil as of now i use the bardahl no problems.. but people say B16 shouldnt use mineral true or false?
mADmAN
1,840
547
3,213
get prepare to replace your valve seals.
agreed...
had the same puff of smoke awhile back... and its just caused by 1 seal...replaced that 1 seal n done.
peeche
395
165
1,543
Sin City, MY
btw.. i used 10w30 vtec lev oil on my former car. b-siries also.
aalto
406
93
3,028
Squee,
Its got nothing to do with your type of engine oil....
Your socket seals have hardened/cracked & need to be replaced... pic below
Oil is seeping through the rocker cover and pooling in your sparkplug socket, the oil then seeps through the plug thread and into the combustion chamber causing white smoke at startup...
Hi all, I'm not sure if I open this at the correct section, if no, Mod pls let me know. =)
This is the seller:
http://www.zerotohundred.com/newforums/exterior-and-body/368407-rx7-re-amemiya-bodykit.html
1 or 2 years ago i contacted him for Gt wing and rear bumper, and i met an accident where my custom rear bumper koyak d, to avoid hassle and save time, i decided to get a plug and play bumper from him, but when i call him this morning, the phone number changed owner...
