B16A Engine OIL
TheSquee
448
12
My b16a is facing white smoke at start up , just a puff of white smoke.
spark plug covered with engine oil
right now using mineral oil 20w50 bardahl.. any suggestions on something similar to use ?
maybe 15w40 ? worried i burn oil as of now i use the bardahl no problems.. but people say B16 shouldnt use mineral true or false?
mADmAN
1,840
547
get prepare to replace your valve seals.
agreed...
had the same puff of smoke awhile back... and its just caused by 1 seal...replaced that 1 seal n done.
peeche
395
165
Sin City, MY
btw.. i used 10w30 vtec lev oil on my former car. b-siries also.
aalto
406
93
3,028
Squee,
Its got nothing to do with your type of engine oil....
Your socket seals have hardened/cracked & need to be replaced... pic below
Oil is seeping through the rocker cover and pooling in your sparkplug socket, the oil then seeps through the plug thread and into the combustion chamber causing white smoke at startup...
A Post Every 5 Mins
Hi, good day. Im driving a wira 1.5 a/b se and I could hear somesort of metal clanging sound everytime I start my car after the engine gets cold. I could hear the sound only when I start the car after turning off the engine for more than two or three hours. Starting the car early in the morning is the worse. Starting the car after 30 mins or even 1 hour of turning off the engine results in no sound at all. The sound will disappear after some time, maybe after 10 mins of drive. Im having...
