Autofaom=Würth assembly foam?
yilmaz101
8
I was sifting through various würth catalogs trying to find information about the so called autofoam. Appearantly würth does not make any product called autofoam. They do have a two component pu foam in their US catalog, but it comes in a 7 oz mixer/injector so that is not the autofoam.....
Well it seems that würth's 1K assembly foam (item number 8921551 in the Turkish catalog) has exactly the same technical specifications as autofam as given in the autofoam website. I'm going to try and contact my local würth representetive to find out about the availibility and pricing of this item. I am thinking of foaming up my car, hopefully in the spring when the weather is a little better. It is currently -5 to -10 degrees where I live.................................
Can somebody please look up in the würth Malaysia catalog for the item number and also the name 1K Assembly foam (in Malaysian of course?).
ocphangaz
62
5
1,508
i know that autofoam is a filler foam that expands and hardened once set.. it's normally used in construction to fill gaps and as insulator.
most basic usage can be found in air conditioning ducts in buildings.
i've seen other brands in malaysia... but haven't heard of your brand... i'll check it out in ace hardware later.
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
not too sure about ur product and the item number bro...
autofoam has many types as well... some is as hard as rock, while some is soft, used as sound insulator..... those cheaper and softer autofoam usually used in bus as aircond ducts or heat insulators.... while the more expensive one (rock hard ones) are used as chassis stiffening... they inject the foam into the chassis, thus making it more solid and tougher....
yilmaz101
8
Actually I talking about the one that is known and marketed in Malaysia as "autofoam" as the generic name is pu foam, pr poly urethane foam. The rock hard one used in chassis stifenning is what I am interested in and the specs are the same as those offered in the autofoam website...
SpeedWanker
155
I've got a can of HILTI 1C Filling foam(model CF-F 750, item# 369811/5) in my house but have yet to use it coz its expired.. it was given to me so i wouldnt know the price and where it was bought but it was definitely bought in M'sia.. apparently it works the same as those body filling foams and some garage uses it too..
yilmaz101
8
From my understanding they appearantl re-lable würth foam with a locally produced sticker to make it look different. However in the autofoam website they give the product characteristics information for the foam they use. If you can find one with same water absorbancy, shear and tensile strength and same density it should in effect give the same results as the one that they apply for RM1xxx, also if you do it yourself it will come out a lot cheaper.
Oct 24, 2006
I know of Hilti's foam pretty well. Its actually meant for construction uses as mentioned earlier. However, they do sell quite a lot to car accessories shops down in JB to fill in the woofer boxes, or however its called. Its also used in the autogate control box to absorb moisture from getting into the circuits
Basically foams perform relatively the same for whatever uses. Its just a matter on its material properties such as what has already been mentioned. In my opinion, it should work fine. It basically suppose to act as a sponge for moisture and noise.
There's Hilti companies nearly the world over and because they have loads of sales people, I'm quite sure you should be able to locate them whereever you are. In KL, their contact number is +603 5633 8583.
Just try a can, should cost in the region of RM70.
Would actually try it myself once I find some time.
Opt-ion
667
Thanks alot for the information, i will try to call the up. My only question is left now is how many can would be just nice to fill up a car on all side panel and chassis...
megizs
11
wurth.. if not mitaken.. my fren is the agent of this product, and its RM 175 per can.. i'll post the details of it when i can contact my fren. the bottle is red and white, it not mistaken.i ll post up the details ASAP
JINEIL2EN
Over 10,000 RPM!
15,321
525
3,213
Island Of Pearl
team99ers.2.forumer.com
Yo dude, do pls updated us if u found the würth things...thanks...kinda interest.
yilmaz101
8
Well bad news, yes autofoam is würth assembly foam, but they have taken it off of the catalog. They have a new type of foam that is basically half the density of "autofoam". The stuff that is called autofoam is a 23kg/m3 pu foam while the new pu foam in the catalog is only an 18kg/m3 foam. So it is not as hard... I am trying to find out about Sika brand foam, as it is more readily avaliable. I think I will foam up my wira this summer.
JINEIL2EN
Over 10,000 RPM!
15,321
525
3,213
Island Of Pearl
pls take some pic when u diy by urself...thanks...
a31gtst
507
I have been considering using this foam for chassis stiffening however can anyone confirm whether doing this will result in rust issues further down the road.
As I am aware, the foam absorbs moisture/water. In Malaysia our climate is very humid and the last thing i want is for my car to start rusting from inside out!
Anyone with feedback on this?
g88
3,082
54
5,148
Sorry to bring this old topic up. Any update on all these foam filler ?
15,390
Feedback from a friend with brand X (shall not be named) and it reduced noise and it stiffened the chassis to some extent. But the stiffness effect seems to reduce after sometime. Don't know why. Speculation is the foam started crumbling after a while. Will need to investigate further with my friends car.
^pomen_GTR^
7,000 RPM
7,514
1,690
The Mines
the sound quality also reduced or still maintain the same level?
Similar threads   Forum
Car Talk
News and Features
News and Features
Do-It-Yourself Garage
RE Club Malaysia
Greetings folks :wavey:
Many automotive users like us would always find a way to improve our ride in the sense of performance, aesthetics, fuel consumption, ah-beng-ness, etc etc. The car makers will not give us everything unless we give them our everything. Therefore we can find many after market parts out there, anywhere. :driver:
While some would spend thousands to churn what's from their car engine, others would only want to spend perhaps a few hundred bucks or less than that in...
