Well, i have done this operation auto to manual for my 4G15. In my case, the mechanic had to cut a hole in the firewall to install the clutch pedal, and had to install the clutch pump and some other things here and there.... but please be careful, when your mechanic cuts a hole in the firewall, better seal the edges properly... or else you guys might end up in corrosion/rust problem....
over all, i dont see any difference in the FC, but power wise is better response than the auto tranny.....
Well, my problem now is... couple of weeks back, a friend of mine test drive my car, and told me that... he's 4G15 stock has better pickup then mine... and the ratio of reaching higher speed of 150km/h++ is faster then my car.... so he told me, that probably i have not changed my ECU...... therefore, my car is running on a manual tranny, and has a brain thinking its running on a auto tranny, practically its a little confiused thats why its performing quite bad....... so, my question is, how am i suppose to upgrade my ecu? am i suppose to re-program it or get a whole new system??.......
Well, my conversion, including patching up and the whole thing cost: RM1700
i didnt swap in my auto tranny, cos i burned it.... :þ
