Anyone Knows the Grade of HKS & M7 Brake Fluid?
DavidLiew
Nov 28, 2011
27
Hi All Sifus,
Just wonder if anyone knows the grade for HKS Super BF5, HKS F-706 and M7 Super B5 brake fluid? Are they DOT4, DOT 5 or DOT 5.1? Have been Googled for the whole evening but cannot find the answer. Hope sifus here can help. Thanks in advance :itsme:
HKS BF5 is DOT4
HKS F706 is DOT5.1
M7 B5 appears to be a DOT5.1 based on its boiling point and the fact that they use this oil in a Honda Civic. Honda's use DOT4/5.1 compatible oils.
DavidLiew
27
HKS BF5 is DOT4
HKS F706 is DOT5.1
Thanks bro. Which one is better? HKS, M7 or Motul? :confused:
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
what car using?
street use car can use Motul Dot4, good enuf.
better one is RBF600, not satisfied then go for RBF660.
HKS and M7 also no problems...im using all these 3 brands, so far all ok.
DavidLiew
27
what car using?
Thanks for the info bro. Mine is 4G18. Just that usually when coming down from Genting the brake feels spongy and the brake oil levels go down. Now changed the brake hose to stainless steel and fill with Motul 5.1. However no chance to try Genting yet :biggrin:
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
if there is no fluid leak...the brake fluid level going down is because the pad is wearing. it will back to MAX when u replaced a set new pads
hi.im currently running on 6a12 tt..i heard about the 6a12tt-rs version in one of the forum ere..
http://www.zerotohundred.com/newforums/2000cc-and-above/255860-ori-perdana-v6-vs-perdana-tt.html
other than just swap engine is there any possiblity to upgrade tt to tt-rs??
anyone ever done that??
need some feedback and comments/suggestion..:hmmmm:
