Aircon finally died...
acbc
4,615
8
KD
After more than 1 year since the last rebuild / service... it finally died on me today at 12:45PM. Sigh... :(
Found some major leaks at the Receiver Dryer. Dang!
Anyone knows the shop recommended by vestax a while ago? Will need to go down to PJ New Town later.
Aarrgghh! There goes my paycheck... :( :(
TiBuN
482
Penang / BM
That 'receiver drying' or usually called 'filter' is cheap right? Any shop can change... maybe i'm wrong though. I changed mine after it was found leaking also, alot of oil on top gathered.
acbc
4,615
8
KD
Got back around 3PM or so from the aircon shop... found a faulty pressure switch on the receiver itself. Lucky, only minor problem. Changed the switch + refill gas for RM 50.
Will definately go back to Hinly in PJ New Town (next to 7-11 for all my aircon servicing in the future. Fast n efficient. Now the aircon is very cold (hehehe... good stuff).
Yong_5290
3,637
49
Klang
hotmail.com
hump....muz recon Kher 2 service his air cond there edi...sumtimes cold like sumtimes not....
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
the "filter" cost RM20 in penang only. The switch may be higher in price if use original.. up to RM70.. the imitation switch usually cannot last long as compared to the originals. I personally changed that switch 3 times already.. now using the original still working fine.
vestax
1,573
7
Damansara Heigh
www.fivio.com
20ringgit filter also does not last long , it gets cloged fast , so better invest on some good brands , don't get those ciplak one then u`ll be fine . yeah the original switch is pretty expensive , but those local made switch are acceptable for the price you pay for .
I have a Nissan sentra year 2003 and i had a lot of jerking issues. Basically i brought it to the shop to diagnose and its said to have sensor issues and they replaced the crank sensor and camshaft sensor and reconnected the ecu and it is still showing the same error so the foreman said the ecu is faults and he cant find a a replacement.
I need advice from how to go from here as my car is in melaka. Where is a place i can get an ecu?
Ecu code number is MEC13-411
Please help! still...
