aftermarket gauge bulb
SatanicsM
108
im using some aftermarket gauge like omoni..i mean old school type..theres 2 type
the one that bulb outside using 2 pin..and one smaller one..where can i repair the smaller one since it already blow
SideWaysGrey
907
125
3,043
Seremban, NS
Im also using a Greddy analogue Boost Meter and the bulb recently blew. Where can i purchase this bulb n replace it? Jln Pasar ?
levin818
1,260
321
3,183
Shah Alam
For Greddy boost meter's bulb, I replaced it with a SMD 0.5W LED (warm white) plus a 100ohm 2W resistor in series. Brightness wise is very good.
wirahybrid
72
1,508
wirahybrid.blogspot.com
just open up ur gauge n replace ur bulbs wit LED n 420ohm resistor. did for mine n its pretty good lighting, bt becareful wen u take it apart, the mechanism is very sensitive
---------- Post added at 09:20 PM ---------- 6 hour anti-bump limit - Previous post was at 09:18 PM ----------
Jin, try look for it at jln pasar, got mine there 4 $3 per piece, most acc shops sellin it at $15 to $18
Lean
UnderCoverProject Founder
221
12
undercoverproject.blogspot.com
Wanna ask the sifus in Zth ere. Normally what type of bulbs is installed at the dashboard panel where we normally see. Is T5 bulb the only choice
Mar 29, 2010
China
maybe i can not help you to solve this problem.but if you have some question about install HID xenon kits,i can help you more
jeyadev
98
4
AFAIK, the sockets and wiring is already done & fitted for T5 bulbs. its like your signal bulbs, in my Satria for example, its wired for T10. so if I want to use a bigger brighter bulb, I have to replace the socket to do that.
for dashboard wiring / socket must also make sure the new socket can fit. again, my Satria uses t10 for the illumination (speedo, fuel, temp) and T5 for the aircond panel & everything else :)
I just had Titans installed on the weekend and I have a question.
Is it normal for the car to be hopping non-stop on the road? My settings are pretty hard right now, i can really feel every single bump and imperfection on the road. BUt is it normal for the car to be hopping? could it be because the shocks aren't "seasoned" yet?
my gf said the car looks like it's shaking its booty down the road =.=
