car came with the digital ac, completely standard hmm will check the contact behind the climate control unit. I should also be able to check the electrical signals going to the resistor (i think) to make sure that nothing is wrong from that point and on.......It sounds like a poor connection somewhere. Digital aircon controller means you tapped some wires, perhaps these connections are just loose.
Your digital air con, temp button up and down, right? and blower speed, L, M, and H?car came with the digital ac, completely standard hmm will check the contact behind the climate control unit. I should also be able to check the electrical signals going to the resistor (i think) to make sure that nothing is wrong from that point and on.......
