Hi guys,
Currently i discovered a problem on the radiator and the reserve water tank.
Yesterday while going go sg.wang, when i parked my car and before off engine, i just realize that my water temp is near to red line, so i quickly off the engine and open the bonet, although the engine is off, the radiator fan still working, i think the ECU know is overheat liow and need some time to cool it down...
ok, so i left my car there and let it cool down... after 1 hour of lepak, i go back and check... the water in the reserve tank was empty. the radiator left 2/3 water only, i know this cause when i refill water, just around 1 little, the radiator full again... then i also refill the water reserve tank before i drove off...
while driving back @ normal attitude, the water temp stays normal...
today i check the radiator and water reserve tank again, the radiator seems full of water, but the water in the reserve tank just left half, yesterday i refill until the full mark. means i travel 45KM need half of water in the water reserve tank...
so now i suspecting the radiator cap is the problem, cause yesterday while refilling the radiator and water reserve tank, i also starting the engine and let it run, got vroom vroom it also, but i notice that there isnt any leak from the radiator, the floor seems dried.
is it cause by the radiator cap? how much to replace ar?
thanks...:D
thanks...:D
