NoName,
When you can supply this model......
KING-EAGLE MODEL =
Remote Features:
This system come with two LCD Remote as shown above.
Remote has 21 different icons which display the status of your car & the system status.
Alert you when the car alarm went off with audible warning and visual alert.
Show the status of doors, trunk or hood.
Monitor the status of your engine, let you know when the engine run and stopped.
Remote has 4 buttons with key lock feature to prevent accidentally pressing one of the buttons.
Feature 24 hour clock, personal alarm clock, LED backlight, Remote trunk release & key locked option
Use one AAA battery, which can be replace easily.
Ultra-low standby power consumption of remote control
Build-in battery level indicator and low battery audible warning.
Alarm & Starter Features:
Multi-Level Security Arming - Multi-Zone - Multi-level security arming allow you to select which of the system's input or sensors to be active or bypassed when system is armed. This system have 5 different levels.
Adjustable Shock Sensor - The sock sensor is built in the communication unit, which has three different adjustment setting for socking sensitivity.
High Frequency - mean long range communication, over 1000m or 3000 ft. This is possible because this system was build using FSK FM technology at 433 Mhz. This provides a cleaner spectrum with less interference and more stable signal. A phenomenal increase in range, even in areas with high radio interference.
Code Hopping - This system uses code hopping technology to increase the security of the alarm. Using this technology will prevent anyone accessing your system with the reproduction of your remote signal by grabbing or scanning.
Smart LED Indicator - The LED will flashes the same number of times as you would press the lock button. (with-in 5 second after you arm your car.)
Door Status Warning - The lights will flash to inform you that some door is not well closed. In case where you temporally park, such flashing may warn coming cars to alert.
Status Memory - In case when the system lost power, the system will remember the status before it goes off, when power restore the system will come back to work a the same state as before it lost power.
Remote Start - Turbo Mode - Under this mode, you can remote start your car engine to run for 1 (default), 2 or 3 minutes after which it will automatically shut down. This is good for quick start & warm up.
Remote Start - Normal - Under this mode, your engine will run for 15 (default) or 25 minutes then shut off automatically after that.
Valet Mode - The system works just as a keyless entry without any security function. You can use remote for locking & unlocking door, trunk release and car finding.
Standard Arming Mode - When arm, doors will be locked and windows will roll up (optional module maybe needed). System will also remind you to arm your car 20 seconds after the key is removed form the ignition and all doors are closed.
Silent Arming Mode - When alarm trigger under this mode, horn will not sound but light will flashes and remote control will set off beeping warning. This feature will free you from "false" alarm which can be a nuisance in residential area.
Panic Mode - Anti-Robbery - Anti-Jacking - Alarm set off and parking lights flashes for 16 seconds and then the engine will shut off even if key is in the ignition. The system cut power off at the distributor therefore the car will not be started again until panic mode is existed.
Remote query function - use this to check the status of your car when you come back in to range after existing working range.
Programmable Auxiliary Output - Press the truck release button for 2 seconds to activate the AUX output, which is programmable to output pulse of 0.5 seconds, 15 seconds or latched signal. Use this option to remote control other accessories for your car.
Remote Engine Start - Long range remote start with gear position checking. Work with automatic transmission and even works on Gasoline as well as Diesel engine.
Multiple signal detection for remote start - Tach, High-Voltage & Oil sensor
Compatible - work with factory security system & remote entry key. The remote can be use with or to replace your factory remote
Multiple user-programmable features
Door/Hood/Trunk sensors
Automatic dome light supervision
Six-tone 120db siren
Optional modules
Microwave Sensor
Ultrasonic Sensor
Automatic windows roll-up module
