1mm bore
normality78
3,052
23
5,138
JB
Guy's,
currently my piston dia was 81mm and i would like to bore into 82mm piston use. i wonder how much significant different would it make in terms of performance?
Fluffy
3,870
>>klang<<
okay.when u bore ur engine 1mm u will increase torque thus increasing hp in theory.based on the calculation
hp = torque(lbs-ft) x engine speed (rpm) / 5250
so,when u bore ur engine,u will increase the displacement.based on this calculations:
.0031414 x stroke(mm) x bore(mm) x bore(mm)
*the value .0031414 is for 4cyl engines.
for 6 cyl it is .0047123 ...this is just for rev.
urs is an inline four rite? :_:
normality78
3,052
23
5,138
JB
Tks for the explanation. Yes, im 4 in-line. actually im aware about the calculation and also more on increasing torque thn hp.
the thing i wanna know is more on how big significant improvement to justify over the cost. i mean something like spending x amount of money but in return only gain back 10hp. worse it does compromise the reliability. so i would need to justify over it. shld the improvement on respond or gain around 30hp or more, thn it do think its justifiable
Fluffy
3,870
>>klang<<
how much will the bore cost u actually?
i dont think it would give u 30hp gains..but it would surely improve on response.coz surely a slightly larger displacement would spit out a lil more exhaust gas thus giving a lil more momentum to turn ur turbine.
normality78
3,052
23
5,138
JB
hm... the labour itself i havent check it out but the piston set will cost me around RM1.3k
MitonCT26
1,112
9
Seremban
isnt it better if you increase stroke rather than bore as you want to increase torque right?
normality78
3,052
23
5,138
JB
miton bro,
i think i've reached the max stroke laio so the next thing i can do is to bore frm stock 81mm to 82mm max.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
wah, need 1.3k arr??...
drop in 1.5L block la... after that do PNP.... no need rebore la..
or like fluffy said, keep a snail inside.... hehehe...
khoyos
2,632
156
5,163
Shah Alam
usually people change piston to alter the compression ratio. 1mm increase in piston bore wont bring such great diffrence, unless u get pistons that has ur desirable compression ratio.
IMHO, rather than increasing the bore (reduce reliability and the painful 1000km running in period), u would do better if u upgrade cams(for NA) or change to bigger turbo if u running turbo engine...
normality78
3,052
23
5,138
JB
drop in 1.5l? what r u talking?
normality78
3,052
23
5,138
JB
hm... tks for the info bro. will think twice now. hehehehe
alvin24
3,109
27
5,148
Hahaha... if your stoke is long, then you might feel it lar. =Þ
But u also need to think in terms of reliability... 4G9X series engines for instance have poor reliability after a rebore.
Guys, I need to re-wrap my steering wheel leather. I have no idea where to do it. All the cushion shops that I went can't do steering wheel re-wrap. Feel free to share your experience/ recommendation. :driver:
