***Does SURBO really work. Pls comment!***
XlimShady
283
19
Saw this online and claims to be very effective. Up to 30% fuel saving??? And more Power. Sounds too good to be true.:stupid: Anyone tried this b4, any sifus? Pls comment.
Thats the link to the wedsite.
http://www.surbo.net/
XlimShady
283
19
Hmmmm i guessed so. Coz its too good to be true. But there are many testimonials if u check out the web site...... =='' Hopefully someone that has used this b4 can give some comments.
xtremeleo
3,247
464
5,183
testimonial are easy to gain from frens sir, i have used it.. there are sum effect, but not gaining up to what they claimed sir. so, no, they dont work as advertised. i wud suggest to stay clear sir
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
waa.... xtremeleo so fast aaa
take it from me who installed it during my NA years... no improvement whatsoever....
xtremeleo
3,247
464
5,183
hahaha, i apologies sir, i had nuthing much to do ler dis morning
DanzEterna
15,910
3,371
www.primeperdanaclub.com
so means surbo is a no no?
cos my bro in law wanna install too...he asked me for my opinion...
iswara gear 4 sudah habis meter oOoo>...
gear 5? engine pecah? ahahaa...
it seems funny when i saw those ads...gear4 habis meter......even a VR4-saga not capable doing that....(unless the meter was wayyyy tooo much over reading) :adore:
xtremeleo
3,247
464
5,183
hahaha, takyah pakai ler.. better to do sumthing else, can abis meter jugek
---------- Post added at 03:34 PM ---------- 6 hour anti-bump limit - Previous post was at 03:32 PM ----------
any1 can prove that surbo is really useless..???
i felt the engine performed better after i removed it sir, so i buang-ed teros jer..
well...surbo was design to give intake air more swirls/twist so it would mix with fuel better...
but....looking at injection intake manifold...that can't be fullfilled since there was separated funnel for each cylinder and the location of injector...
if it was on carbie engine it might help a bit..but not much....
plus..the twisting parts restrict the air-flow..so u gain a bit but loss back by intake restriction....equals to 0 or worse....-ve improvement... :adore:
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
for engines running MAF, i advice u better stay clear of surbo or anything which interrupts the air flow through the sensor... because when u force the air to pass through the air ram and sensor fast, ur MAF will detect "higher" air volume flowing through it, which is not... hence, injecting more fuel, makes ur engine runs richer, ruining the fuel consumption and performance...
raja_emeperor
741
28
one unit of surbo installed not sufficient to give you the boost kick, put 4 of them will be equal to td05 turbine.
if u want play 400 meter drag better go 6 unit surbo..and dun 4get to put it at your rear cat exhaust system.
then to balance up the power produced, dun 4get to upgrade your breaking system, if no budget, go accessories shop to install brembo or endless caliper.
mkdreamervl
327
32
Better install 20 units of Surbo all along ur intake hose also... Possible 800hp gain.
On a more serious note. Bought it used it and its rubbish.
That will be all.
Ax XX said:
I did my silver car via an authorised Mxxxxxxxx detail shop. 3 to 4 layers coated on it but frankly speaking I do not like the outcome. The paint turns 'sandly feel' in less than 2 months. What I do to preserve the smooth surface is coat it up by 'Pxxxx Sxxxx' once or twice a month.
Hi Buddy
thanks for bringing up - 2 issue i would like to clear up here
There is no such myths of 3-4 "layer coat " or 3 or 4 steps
(what ever malaysia car wash / polish centre)...
