installing CAI?? and only used the drop in filter?
series5401
373
17
Kuching
installing CAI?? and only used the drop in filter,
does the CAI will add some improvement ??
tq sifuuuuuuu
yup..
cold air gives impact in engine performance..
im not sifu but i did ask a sifu last time..
hot air are not good for engine to breath..
MKMD428
876
190
5,043
johore
can. provided that the CAI directly bolted to the box. like this:
if its not fitted like that, then i'm afraid u wont utilize CAI properly
Che.Det
124
u all really nice la, thnxxx for the photos.
1 more question,
there are a lot of CAI in the market, so which one is consider better/good?
name it plssss? thnxx
LittleWhiteWagon
1,656
187
P.J
1 more question,
Bro, CAI is just a bendy pipe with a metal cover. Takkan you need forumers to tell you WHICH piece of odinary plastic to buy right? :stupid:
series5401
373
17
Kuching
1 more question,
if u want to save budget, use a kitchen hose and diy to your car..
if not, u can buy the CAI itself.. hahaha..
Che.Det
124
yes i know what is CAI,
but i mean, does they have any specific branded ?
or every single CAI in the market is the same. zzzzzzzzzzzzz
MKMD428
876
190
5,043
johore
the plastic CAI type, as shown previously in picture is good.
the aluminum CAI type, was not that good. material seems to be degraded as time goes. bending wise also not that good compared to plastic
there's no specific brand type. it is all the same.
i only noted a few differences:
1. the length of the CAI. some can be stretch long, some short.
2. some CAI got mesh wires/protective grilles at the intake part (the one that u always see on bumper)
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
basic rule when routing ur CAI hose...
- do not get near to heat source, such as extractor, radiator, etc...
- do not bend it beyond 90 deg... if not u will have air flow restriction problem...
- transition from bumper into ur engine bay, a vertical path can ensure the least water being sucked/blown to ur air filter...
darrengoh89
222
most important thing is if direct fitted the CAI from bumper to the airbox ...make sure it is not in air tight ... drill some hole in your airbox ....else when banjir time ...each time you throttle ..i bet the water will goes up like you are drinking water with a straw like that .... juz some advise here coz i used to be one of the hydrolocked engine victim before .
RASHID
612
6
just info for u..
my last time car..
i demod it..
the last thing was my cai..
every single time i demod somethin the power loss was just too little to feel..
the cai help imporve alot..
as prove after demod the cai the power loss was notice...
now usin on myvi..
good response in pick up..
series5401
373
17
Kuching
bro sky..
wana ask on your cai..
like yours, u install it troug a hole on the right part right..
wat if i just put it from the hole to the cleaner.. not trough the hole..
got any affect or not..
Pic 1 - Remove the original regulator with 2 screws, first remove the two hose that is connected to the regulator one with the clip and the other one is the vacuum hose.
Pic 2 - This is how it looks when taken out if afraid keep the O ring in a safe place.
Pic 3 - U will need to grind off the section where my thumb and pointer is holding with a grinder.
Pic 4 & 5 - Notice that part with scar, just grind a little by little until u see the inner core.
Pic 6 & 7 & 8 - Sorry quite blurr...
