DIY Honda ECU Repairs- P30 P08 P27
E-Tech
1,115
256
3,183
Johor
bro can you rechip a b16a P30 ECU ?
mine is an auto , dunno rechip to what is good can recommend ah
and i feel my car is running too rich now.. the FC for full tank RM70/250-270KM
Civic EG8 92-95
please advice thanks :D
thesquee.....something wrong with yr car...mine also b16a auto n before PnP i could get 480-500km per full tank and needle only halfway thru the redzone. even after my bothced PnP i still can mange 400km per full tank.
E-tech...i remember u telling me that u did re-chip...but what chip u using? hondata dun say ar...too blardy expensive... :banghead: i may need yr services one day...on advise of a sifu here i plan to get a b18c GSR VVIS intake manifold n set the 2nd butterfly valve to open at a certain RPM...can imagine?
Yes.... i do re-chip also...
Chips available for B16A-->B18-->B20. Feels, Spoon, Jun & Mugen
Me running on FEELS chip...
thesquee--> your car B16A auto? Is your ecu for auto?
High FC--> sensor problem e.g o2, map, or tps position out
running on bigger injectors?
Did you do some modifcation?
bigtroble
Sep 19, 2010
5
psl, fl
got a d16 for q25
drop in
and cranks up
thanks again
but now finding out it has cel code 36
traction control
any way to trick it?
or burn another chip
E-Tech
1,115
256
3,183
Johor
got a d16 for q25
drop in
and cranks up
thanks again
traction control
Good job!!!
Sorry can't help u on cel36.
Don't get that problem over here..
Tq.
invicta
532
2
bro. do yo know the value on smt cap around 4ea big transistor (vtec,auto function) on p30? hard to measure la..
E-Tech
1,115
256
3,183
Johor
Body mark of the chip cap "J1".
The actual value will tell u tomorrow after i measure it.
tq
tks84
128
wahh... what a useful thread.. congrats for mr tan. still remember me? hehehe.
last friday, my car suddenly died on fast lane at mrr2.. kane..
first impression, suspect was distributor kong already.. call pomen, changed 2 set distributor oso cannot.. swap p08, lucky can start.. fuhhh..
saturday morning, found 5 cap leak.. but small leak onli.. hard to find with bare eyes. changed and ... vroommmm..my ecu alive again..
so better change your cap for now.. get mr.tan to do it with minimal cost..
cheerss..
Bro where did you change your caps? in KL? mine need to change too but i don't know where to change in KL...anyone know?:adore:
tks84
128
if DIY then where can i get the replacement chip?can get at any electrical shop (eg jalan pasar) or i just send to the electrical shop to change the chip?
cause you too far lar...johor lar....if i take out my ecu,how i going to work,out?
:bawling:
E-Tech
1,115
256
3,183
Johor
Yes = Jalan Pasar can get those capacitors... rm 0.5- rm1/each
E-Tech
1,115
256
3,183
Johor
PR5...OBD.... Same gang as PR3 or PW0.
These type does seem to have cap leak trouble.
hi there,
anyone have any idea the max i can bore my 4G92 non mivec block?
from 1597cc to ???
if bore ady what other items must be change or replace?
