Sticky Gear Shift on CK4G93T
ehdrian
I Don't Care!
3,310
280
1,683
Bros, i've difficulties engaging gears when the engine is cold..However things are much better when the engine is warmed up but still gear shifting isn't really dat smooth especially down shifting(5th to 3rd sometimes can't engage, 2nd to 1st got grinding sound if i do it quickly)...using Redline 75w90 gear oil, dat's wat i've been told frm the prev owner..Can somebody tell how can i solve this prob?..Thanks in advance
p/s: using stock clutch and still in good condition..
93na
597
20
i havin the same problem bro! 1st to 2nd got grinding sound.... 4th to 5th sure sticky wan....on my sgti... some say cause of clutch better if used racings wan! also dont know la cause at time i do drive fast scared later on long term gearbox kong....
BLANk
1,750
6,757
Sardine
www.zerotohundred.com
Redline 75w90 gear oil...using the wrong gear oil alrdy la and this is why that cause you difficult to shift the gear...its for rear differential not for transaxle or transmission...and its GL-5,it will corrosive the bronze or brass made synchronizes...
try to switch to MT-90 GL-4...it might solve the problem....cheers~~~:biggrin:
ehdrian
I Don't Care!
3,310
280
1,683
then how ur solve the prob?..wat gear oil u using?..
---------- Post added at 12:53 PM ---------- 6 hour anti-bump limit - Previous post was at 12:50 PM ----------
really ah bro?..how much is dat motul gear oil?..
zac
1,347
231
Johor Bahru
But if got grinding sound while shifting from 2 to 1 then maybe your synchronizer already kong... i used to have this sound, very irritating...
ehdrian
I Don't Care!
3,310
280
1,683
ehdrian:
ya bai~~~
not motul la...
its one of the redline product too...redline MT-90 75w-90 GL-4...rm55/quart...:biggrin:
bro, wat's GL-4?..their grade of viscosity?..the greater the number for the GL means it's not suitable for my gearbox?..i plan to use TORCO SGO-GL 6 gear oil but i'm afraid the gear shifts will become even more difficult cos the GL number is greater..
---------- Post added at 07:30 AM ---------- 6 hour anti-bump limit - Previous post was at 07:29 AM ----------
will try to change the gear oil and see how, if synchronizer rosak then teruk ade.. =(
BLANk
1,750
6,757
Sardine
ehdrian:
GL-4 its a grade frm the API....for transaxle and transmission use only GL-4 but some can use both GL-4 and 5 depends on the manufacturer...
GL-6...myb its both compatible?haven seen before yet...because most in the market now are GL-4 and GL5...frm mineral to fully syn...
93na
597
20
haven done anything yet! sending my car to workshop on monday!!!! changing the clutch plus servicing the gearbox,, hope things will be better!
ehdrian
I Don't Care!
3,310
280
1,683
ehdrian:
bro, for my case, GL-4 is good enough?..thx for the explaination bro.. SGO synthetic racing gear oils >>--check this out..
93na: i'll wait for ur feedback ok.. =)
The Marketplace Top Posts
Afraid of missing out our promotions?
Want to be the first one to find out what promotion we are having?
or just simply want to hear from us...?
Please reply with your email address so that we can include you in our mailing list. Just as simple as that.
What will you get?
  • be the first to find out what promotions we are running even before we...
