audio problem
Technically speaking one side speaker having consistency issue should be relate to wiring problem. I think all accessories shop can fix the issue.
I stay in butterworth, I only know shop in butterwoth.
Hopefully is wiring problem...U still using Bose Player???
I have sold that Z, then bought a another base model manual transmission Z for track purpose only. My new Z use normal JVC player and simple speaker, no woofer.
My previous Bose player is great, never give me me problem. I have a suggestion for you. If you don't like the existing Bose player, you do not need to remove it, because fixing other player on the dashboard maybe ugly. Actually you can add another player to the Bose player. New player will be fixed in the navigator DVD bay, behind driver seat. You can use this new player to play song and watch movie on the stock LCD screen. You can get local radio channel as well with new player. Volume control remain on the steering and other function managed by remote control of new player.
Stock Bose player will not removed and it still can function like normal. Navigator DVD player relocate to somewhere nearby the woofer.
fixing another player on the dvd bay? hmm sounds like a good idea..any recommendations for the player?
I aiming for 2Din-player like Kenwood or Clarion wif GPS modem and replace wif my Bose Player because Bose player dun have USB and just a 6CD chg....izzit ok???
Is up to you, but you need to know, after replacing the stock Bose player, your dashboard will not look as smooth as stock condition. Furthermore your volume control on the steering will no longer working. I suppose your 2din player come with LCD display, if that is the case, you have 2 LCDs on your car. If you ask me I will say this is a waste because since stock LCD can be connected to additional player, then why install another.
There is a small AMP in your rear boot for your Bose woofer and speakers (diagram attached). I not sure it actually work directly with the woofer or go throw Bose player. I have 94 pages AV diagram of 350z, it is very complicated and seems like the player connected to so many things. I guess the shop technician will not understand how the wires are connecting to each other and they will not spend time to investigate. Normally what the shop will do is to ignore whatever they don't understand and lay a new set of wire to connect to you speakers and woofer, of course, bypass stock AMP and other electronic instruments. They may ask you to get a new AMP as well.
Furthermore, the LCD fix at player area will have glare problem. Stock LCD display position and angle has been calculated in such way to reduce the ratio of luminance between the task and the source of glare.
About the AMP,the seller told me before that Z33 inside got small AMP and maybe have to spend some time to check wheater our AMP can support for new player like Kenwood or wat so it sounds like calling me to chg another AMP too and i have no experince about ICE so I just tell him I will consider about it first...The steering volume control is ok wif me even this function dun have and i wanna chg a 2-din player LCD type but i still worry about their skill...U got any pro shop for Z33???Butterworth oso nvm...I will go and check it out...YSL,u know Sunrise at Gurney there rite?Got 1 audio shop named AcousticEdge,izzit ok if i take my car go there for service or upgrade???
u can try that autogadget shop in damansara..looks good to me..am thinking of installing mine there
Techno350z stay in Penang la brother.
Aiyooo...How about Butterworth???Got any recommended shop???I dun want take to some unknown shop anymore becoz they always potong ppl 1...haiz~
Try one shop near PC DEPOT Perai, shop name something like SKY, the shop owner quite knowledgeable.
Gomez...I stay at Penang la...thank for the reply....^^...
---------- Post added at 05:49 PM ---------- 6 hour anti-bump limit - Previous post was at 05:36 PM ----------
Oh~I just found a shop kinda good for me at Sungai Dua and maybe changing Kenwood DDX6036...They will check for me and see wheater Z can support or not...
Good luck!
Hey, did you guys mind posting a photo of what you have done with your audio unit specially the head unit. It will be good for people like me and techno350 who want to upgrade the audio system. It should give us some idea too. Thanks in advance!
Hi, someone bought my Y-pipe today. While I looking my Y-pipe in store, I realize that I still have one Alpine Amplifier with me.
The AMP previously advertised in The market place but was too long ago and I have forgotten about it.
http://www.zerotohundred.com/newforums/ice-in-car-entertainment/317006-alpine-mrp-f240-4-channel-car-amplifier-40-watts-rms-x-4-a.html
Any one who interested in upgrading your sound system should consider this, I'm now letting go at RM400. I want to say bye bye to all this stuff.
Those who want stronger bass please consider.
Amp SOLD
I will changed my HU and upgrade the whole system soon , will upload and share some ideal with ur later ...:proud:
Cool! Cant wait for the photo!
In the mean time, for those who having problem with your Bose amp cutting in and out, you can try this moethod. It only take less than 20min and you can do it yourself. It May fix your left and right speaker as well.
Cheers!:burnout:
http://www.350zmotoring.com/forums/350z-problems-troubleshooting/56208-fix-bose-amp-cutting-out.html
---------- Post added at 09:53 PM ---------- 6 hour anti-bump limit - Previous post was at 09:26 PM ----------
And here is the fix for the famous left speaker cutting in and out when you accelerate or braking. This event happen normally happen when you listening to CD. If you tune in to FM radio, both speaker are working fine. As someone mentioned before, it was the player not the speaker and to be exact, it was the connection ribbon. Try below method. Work for me :adore:
http://www.350z-uk.com/forum/viewtopic.php?f=35&t=29516&view=next
A thread every 60 seconds
